Brake Heat/Noise
Old Jan 22, 2008 | 01:59 PM
eidman3372's Avatar
Brake Heat/Noise
I wanted to see if anyone else has had this issue recently (I saw some previous threads from a while back). My RX8 front brakes were replaced (rotors and pads) by the dealer in June 2007 when the car had around 38,000 miles on it. In September 2007, the brakes started making an obscene squeal that sounded like a bus stopping and emitted a very noticeable burning smell. Over two months I took it into the dealership but they were not able to duplicate the sound. Finally, in December 2007, I took it in and they duplicated the sound and provided full replacement of the rotors and pads. At that time my car had 40,600 miles on it. My car now has 41,300 miles on it and the brakes are making the same sound and emitting the same smell - 700 miles later. I took it back in and Mazda USA is unwilling to admit any fault on their part, stating that it is my driving habits that are the cause of the pads overheating which is causing them to crystallize and make noise. Therefore, they want to take my brand new rotors that have 700 miles on them, re-tool them and replace my brake pads solely at my cost because mazda USA won't take any responsibility.
Now, I have had my car since it had 24,000 miles on it (I bought it used). I drove the first 14,000 miles with nothing but a mild intermittent high pitched squeak - regular brake noise with nothing to be concerned about. It was not until they replaced the rotors and pads that the brakes began making noise. I have now had them replaced twice with the same result (the first was due to normal wear and tear). I have not changed my place of employment or where I live. I drive the same mileage today to and from work that I did 3 years ago when I bought the car and I do not drive it very much on the weekends. I am frustrated and at a loss on what to tell mazda since my driving habits must have changed drastically since I began driving over 19 years ago as I never had this problem on this car or any other that I have owned before. Interestinglly enough, I had a local brake service replace my rear brakes (rotors and pads) around the same time and have never had an issue with those.
I know that there is a TSB issued in 2006 which I am not sure if it is still applicable today. My dealership did not know of the bulletin.
HELP!!!!
Old Jan 22, 2008 | 02:04 PM
StealthTL's Avatar
Metatron
Just get a set of good aftermarket pads (Hawk, etc.) and move on. Don't machine rotors that only have 700 miles on them.
S
Old Jan 22, 2008 | 03:07 PM
Spin9k's Avatar
Momentum Keeps Me Going
"Insanity is doing the same thing over and over and expecting a different result"
Step back from the problem. Whatever things 3 brake rebuild did wasn't the problem you needed solved. Ok so what is the problem? Sorry but it's difficult question and answer.
To know how well any other those brake jobs were, you're going to redo the brakes yourself (not really that much work), or sit with the guy who does it for you and ask the right questions.
Maybe they didn't grease the brake components during assembly or install the shim kits right or even at all! Perhaps they didn't clean up the calipers, get all the crud off, rather just threw the new parts in. Sometimes the small details are what shops (dealerships, whoever) don't bother with. And it could be something they didn't want to do, like a coroded piston or broken dust seal. They don't do a rebuild, your going to have atrouble.
And for symptoms like noise, these types of details can be just what was needed to do a compete and successful overhaul.
Old Jan 22, 2008 | 08:40 PM
Carbon Kevlar brakes from Porterfield aare what you need.
Make sure they use anti squeal.
http://www.porterfield-brakes.com/
Old Jan 22, 2008 | 08:45 PM
If it was me...I'd pull the calipers...and clean and lube them...and re-install new pads
If you don't know how to do that..you either have to learn how...or take it somewhere that can do it right.....
Where do you live...maybe someone local to you can help?
hufflepuff
May 30, 2016 10:45 AM
Road Cone
Nov 6, 2015 01:52 PM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
