Best Alignment Settings for Street
Old Jan 21, 2008 | 03:45 PM
kennyfrc1's Avatar
Toe:_____________?
Castor:____________?
Camber:____________?
What are the OEM Specs?
Old Jan 21, 2008 | 03:49 PM
road1will's Avatar
Free!
Just go to GTE
Old Jan 21, 2008 | 05:08 PM
Juice's Avatar
I made some poos
Stock alignment would probably be best. Thats what mazda designed it for.
Old Jan 21, 2008 | 05:35 PM
TurboEight's Avatar
Booost.
Even dropped?
Old Jan 21, 2008 | 07:20 PM
search for threads started by phile hendrie.
it was the only good? and thread he was involved in..
Old Jan 21, 2008 | 09:27 PM
nuke0907's Avatar
Never Blend In
hahaha. nice avatar swoope.
Old Jan 21, 2008 | 09:55 PM
https://www.rx8club.com/showthread.p...ght=great+post
wow,
i had trouble finding it..
it might help..
nuke, sorry i missed you in va..
Old Jan 22, 2008 | 08:40 AM
kennyfrc1's Avatar
My settings at the last alignment were -.7 Front Camber L&R, and -1.5 Rear L&R. What effect does that much negative camber have on handling? Why do you want more negative camber in the rear? The car seemed to spin easily in first gear while turning. Maybe because I was riding on the inside edge of the rear tires.
I have new wheels now(Gram Lights 57F 18x 8.5 with +45 offset). So I am sure the alignment is off as a result of the change and now the rear of the car feels "Loose".
Old Jan 22, 2008 | 09:37 AM
altiain's Avatar
Sparky!
Changing wheels and/or tires has zero impact on alignment.
Old Jan 22, 2008 | 01:58 PM
lshu's Avatar
Driving makes me :)
You usually want to have more negative camber in the rear to prevent the loose (oversteer) feeling, but it seems like your settings should be fine for the street the way it is now. If you say that it feels loose in 1st gear, it's probably because you're engine braking while turning, throwing the weight to the front of the car. More neg camber = more grip on turns, but slightly less on the straights. The purpose of negative camber is to create a more flatter contact area when the suspension loads during a turn, giving more grip. BTW my settings are -1.0 front, -1.5 rear, 0 toe and balance seems perfect and tire wear even to me, but I usually drive aggressively.
gwailo
May 14, 2024 06:57 AM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Silverhks
Sep 16, 2015 11:55 AM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
20b-3rotor
Sep 2, 2015 08:54 AM
