EMU and the Boomslang harness
Old Jan 18, 2008 | 06:18 PM
Phish806's Avatar
I am planning on purchasing emanage and figured that the boomslang harness might be the way to go since its supposubly plug and play. i was wondering if anyone was using there harness for there 8. If so how well does it work (is it actually plug and play, andy modifications, not work at all, etc.) On there sight they list 4 options as for the RX-8 they are as follows: Air and Water input , Knock and water input, knock and air input, and dual knock input. does anyone have any suggestions on what would be the best for the 8 and or what the different harness are for. just a little confused on the differnt harness types but thanks for the help.
Also, my car is an 05 6mt currently N/A with plans to go nitrous.
Old Jan 18, 2008 | 09:16 PM
MazdaManiac's Avatar
Neither of the harnesses are completely PnP.
It really depends on what you are trying to do.
Unless you can get the Boomslang for less than $200, just get the GReddy harness.
Old Jan 18, 2008 | 11:11 PM
Phish806's Avatar
i was trying to refrain from cutting into the facotry wiring ... is this possible at all?
lets say i do decide what the hell and start cutting into the facotry wiring, is the one $200 greddy harness the only one i need?
Old Jan 18, 2008 | 11:24 PM
You don't need to cut into the OE wiring with either harness.
Old Jan 18, 2008 | 11:35 PM
Phish806's Avatar
well then ... my bad... i thought with the greddy you did. what is the deal with the "A/F Option port harness" on there website? what option does this allow you to use. i suppose i could search a little more also ... which is what i am trying to do as i type this ...
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
05rx8mazda
Nov 28, 2015 09:42 AM
Evan Gray
Nov 24, 2015 01:00 AM
RotaryMachineRx
Sep 29, 2015 10:26 PM
