Wideband o2 bung placement
Old Jan 17, 2008 | 10:12 PM
turborx8's Avatar
Boost 4 Life
Where is the proper place to weld in a bung for a wideband o2 gauge?
I received the wbo2 kit for the mazsport interceptor-x today and on the instruction provided it says to weld the bung a few inches behind the front factory o2 sensor and slightly stagger the new sensor so that it receives direct exhaust flow.
My local shop welded a bung for my AEM UEGO gauge onto the greddy downpipe adapter. Something tells me that's not the correct spot and that my AFR are noo accurate with the sensor that close to the turbo.
Greddy downpipe adapter
Old Jan 18, 2008 | 12:03 AM
MazdaManiac's Avatar
If you still have a CAT, mount it just before the exit flange on the downpipe, pointed at the transmission (right at the bottom of your circle in your pic).
If you don't have a CAT, mount it at the end of you midpipe.
The sensor will live longer there.
Look at that little, tiny turbo.
Old Jan 18, 2008 | 12:06 AM
turborx8's Avatar
Boost 4 Life
Thanks again for your help. That makes perfect sense.
The further away the sensor is the less heat it will absorb. I do currently have a cat but I plan to get the Mazsport midpipe in the next few months.
Hmmmm....
ToM18nY
Jun 6, 2011 06:50 PM
BSchwemer
May 23, 2010 04:35 PM
LiL BenNy
Aug 19, 2008 09:58 PM
brillo
9
Dec 5, 2006 09:14 AM
