Fog light keeps burning out
Old Jan 17, 2008 | 09:59 AM
white311's Avatar
9K Smokin!
My driver side fog bulb has burnt out 2 bulbs in a very short amount of time. This seemed more like an electronic issue. Does anyone else have this problem? Is there a short?
Thanks in advance for advice!
Old Jan 17, 2008 | 10:08 AM
VolcomStoneX's Avatar
Hi, Let's Make Out
are you still under warranty?
Old Jan 17, 2008 | 10:15 AM
HCTR154's Avatar
Not sure about the warranty thing, it's worth a shot if it is still under.
If not, pay attention to when you install the bulbs. It's very easy to misalign those small tabs when turning them. It may even feel like you have "locked" it into place, but you may have cross threaded those tabs, even though they are all different sizes. Just look carefully at the base of the bulb and those mounting cut outs and you will see what I mean.
I have been through more fog lights than I care to remember, but recently put in some Hoen Xenon match bulbs and they holding up well. Also, I use my fogs as daytime running lights, so maybe this is just a necessary evil for more visibility.
And, avoid autoillumination products, they seem to burn out very quickly!
Old Jan 17, 2008 | 10:22 AM
white311's Avatar
9K Smokin!
I put on aftermarket parts. So, no.. It just started happening recently. The bad thing is I'm using 7000k bulbs to kinda match my the HID's, so the aren't cheap.
I will check the bulb alignment.....but I burnt my last one out in 2 months and now this one took 1 day.
What wattage is best....I know 55w is stock but they are weak!
Old Jan 17, 2008 | 10:26 AM
HCTR154's Avatar
I have had very good luck with these.
http://www.hoen-usa.com/fog.htm
Old Jan 17, 2008 | 10:29 AM
white311's Avatar
9K Smokin!
I will look into it.
Thanks HCTR
Old Jan 17, 2008 | 10:36 AM
HCTR154's Avatar
Also, one time when I was swapping out some bulbs, some moisture was all inside the actual fog light housing, which obvously caused it to burn out.
I went and got my lovely wife's blow dryer and proceded to dry out those housings as well as I could before installing the Hoens. Just a thought...good luck.
Old Jan 17, 2008 | 11:17 AM
white311's Avatar
9K Smokin!
Dont lie. It was your blow dryer...haha
Old Jan 17, 2008 | 11:23 AM
Hi, Let's Make Out
hey, when i go to the link there a few to chose from, which ones did you buy?
Old Jan 17, 2008 | 11:24 AM
Hi, Let's Make Out
i got it,nvm
thanks
white311's Avatar
9K Smokin!
i would assume the H11 Xenon Match
Old Jan 17, 2008 | 11:36 AM
Hi, Let's Make Out
there is a form on there that tells you
vapor2
May 4, 2020 03:53 AM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
wayloco
Sep 1, 2015 09:03 PM
