water..tail light
Old Jan 15, 2008 | 04:26 PM
complex's Avatar
Thumbs down water..tail light
its not under the 4 year warranty anymore..what can i do?
Old Jan 15, 2008 | 04:47 PM
SayNoToPistons's Avatar
Wheels, not rims!!
Take a heat gun to it and take off the lens. Clean it and seal it again =D
It's funny how Guiffre Mazda in Brooklyn told me its perfectly normal.
Old Jan 15, 2008 | 04:51 PM
Socket7's Avatar
ಠ_ಠ
I'd go looking for a junkyard replacement, but since its "broken" anyways, may as well try sayno's idea first.
Old Jan 15, 2008 | 07:36 PM
wmitz's Avatar
So how does one use a heat gun to take off the lens? I've got the same exact problem. How did the water get in? If there's a hole then it will just happen again, no?
Old Jan 15, 2008 | 07:40 PM
Velocity's Avatar
Hey, thats what mine looks like too. My car is still under warrenty, but the Mazda dealership says it's not covered. WTF?
Old Jan 15, 2008 | 07:42 PM
VolcomStoneX's Avatar
Hi, Let's Make Out
you need new gaskets,the early model ones suck, ive got both tail lights replaced 4 times each,
Old Jan 15, 2008 | 07:45 PM
Hi, Let's Make Out
http://www.finishlineperformance.com...14-07-1795.pdf
take the TSB to them, It is something covered under warranty, id bitch until they fixed it
Old Jan 15, 2008 | 08:08 PM
Scrapin 240's Avatar
he said its not under the warranty anymore since 4 years have past. try to get new gaskets/seals.
Old Jan 15, 2008 | 08:54 PM
Hi, Let's Make Out
i was talking about velocity, he said he was still in warranty
Old Jan 15, 2008 | 08:56 PM
DOMINION's Avatar
I don't buy Kool-Aid
Lightbulb
Call and send a email to Mada of North America
Old Jan 15, 2008 | 09:38 PM
awww...my bad.
yeah its covered, they just changed my d/s one out yesterday.
Old Jan 15, 2008 | 09:44 PM
KraZy K 02's Avatar
My rear taillight is like this as well. I just haven't had time to take it in. I suppose I'll call them tomorrow and schedule an appointment to get it fixed. I just printed out the TSB and I'm going to bring it in case they give me a hard time.
Old Jan 15, 2008 | 10:20 PM
It seems that MOST dealership does not know about the gasket problem. They just replace the whole light. Like me
guess what, after what, 3-4 months ? its fogging up again ~~~~ starting @ the right side now. not major, but its there ... *sigh*
Old Jan 15, 2008 | 10:21 PM
Print the TSB out and bring it to dealership, its cover if u're in warranty (they replaced both of my lights like 3-4 times already)
Old Jan 16, 2008 | 12:01 PM
complex's Avatar
im thinking of getting a 2 yr warranty extension.the car does have 1 other problem.i was quoted a price of $2274 by a dealer.. in the mean time, ill see what i can do about the water..
Old Jan 16, 2008 | 12:24 PM
U're in Queens ? Im in Queens too.
What part are you in ? maybe we can meet up and see what your problems are.
Old Jan 16, 2008 | 12:27 PM
R Magic's Avatar
I had the same problem, but didn't feel like it needed to be replaced. So, I got some clear silicone and applied it around where the lens was attached together, and the problem was solved!
Old Jan 16, 2008 | 12:30 PM
Can you point out where you apply the silicone. I think I have an idea where to apply it, but just want to be sure.
Cuz this **** is making me sick as well.
Old Jan 16, 2008 | 12:38 PM
R Magic's Avatar
Just between the clear plastic and the black plastic part. But, we sure to do it all around the whole light, I would recommed removing the tail light and doing it.
Old Jan 16, 2008 | 12:39 PM
I remove my tail light like 10 times already
I will give that a try, need to get some silicone sealant tho. Do you think the ones that they use for sealing oil pan works ?
Old Jan 16, 2008 | 12:52 PM
dozer's Avatar
on his 3rd rx8
this happend to my first 8, what i did was loosen one of the screws on the back of the tail light, just loosen a lil, dont take OFF!!...so this way air and moisture can escape and not build up on the inside.....
Old Jan 16, 2008 | 12:56 PM
the stig's Avatar
I like roast duck
my is like that but as as bad. im out of warranty, so i guess ill just buy one from ebay. don't think the dealership can help me with anyway with out money involved
Old Jan 16, 2008 | 12:59 PM
jp4wd's Avatar
The Big kahuna
i had the same problem when i first dot my 8. It doesnt matter weather its still in warranty or not. Theres a TSB for that so the dealer should give you any trouble to get that replaced.
Old Jan 16, 2008 | 02:10 PM
complex's Avatar
i think ill try the sealant idea..
im near the bqe off northern blvd.maybe..
yes it does.you need to be under warranty to get tsb work done.
Old Jan 16, 2008 | 02:16 PM
Isnt that near the flushing area ? what problem you have with your car anyway ?
