View Full Version : misfire...after coils and plugs changed.
Changed plugs and coils Thursday last week, car ran loads better, got home last night reved her up and cel flashed and then went solid...wtf is going on. Flamers go ahead, right now I just don't care, just hope someone will take pitty on me and help.
Thanks.
Did you double check all of the connections?
Re torque the plugs?
nycgps 01-15-2008, 12:01 PM MAke SURE your plugs aint too loose or too tight.
usually I do it like this, hand torque it all the way to the end, then get the Plug socket out and give it an extra 1/2 circle turn.
my plugs work for 10K miles already :)
Lets not forget, You might want to reset the ECU, especially after those stuff has been changed.
and, misfire happens. rapid acceleration and deceleration might trigger it too.
That's what I thought so I did that last night, seems to run fine though other than a little and mean a little sputtering above 7000 rpm.
nycgps 01-15-2008, 12:07 PM That's what I thought so I did that last night, seems to run fine though other than a little and mean a little sputtering above 7000 rpm.
if its really minor then u' should be fine.
but if you can feel that it *chokes*, something is not moving smoothly. at least now my engine never choke, all the way to 9 K baby !
What you can do is throw a bottle of GOOD complete fuel system cleaner like redline into your tank. And run your car HARD, rapid accelerate and decelerate around the rpm range.
it helped me, so it might help you. :)
MazdaManiac 01-15-2008, 12:23 PM Be absolutely certain that none of the plug wires are touching each other (not to mention that they are attached to the correct plugs).
Huey52 01-15-2008, 12:44 PM Should also change out the plug cables. Stock cables are notorious for becoming electrically porus over time, causing crossfire/misfire. The new coils and plugs are only as good as the electrical conveyance between them.
staticlag 01-15-2008, 12:49 PM Make sure that the connectors are fully seated on the plugs.
A full connection is one where the plug boot completely covers all of the ribs on the side of the plug.
I will try these things and let you know what I find. Thank you.
Jedi54 01-15-2008, 02:15 PM I'm leaning towards the cables not being attached properly OR possibly being hooked in wrong. (simple error, could happen to anyone)
I know when I installed my Racing beat wires, those S.O.B's were pretty tough to get properly attached.
Good luck, hope it ends up being something simple
Huey52 01-15-2008, 02:56 PM Yep, try the simple first. But, if you went the expense of new coils and plugs, you should also go new cables.
^^agreed I'm :banghead: for not doing them, ordering new wires today.
took car to bountiful mazda here and they say bad coils...bulshit and low compression on both housing. NO WARRANTY due to intake/exhaust. calling MNAO to find out what to do, any tips?
They have to prove the mods voided the warranty - not the other way around; might want to remind them of that...
I told then to provide it in writing how my intake and exhaust blew the compression on my engine, and he said they don't have to, it's up to me to prove my parts didn't do it. So when I get my car back today I am gonna shove the Magnuson Moss Act up his ass.
LionZoo 01-17-2008, 05:01 PM I told then to provide it in writing how my intake and exhaust blew the compression on my engine, and he said they don't have to, it's up to me to prove my parts didn't do it. So when I get my car back today I am gonna shove the Magnuson Moss Act up his ass.
Keep us updated.
nycgps 01-17-2008, 07:47 PM I told then to provide it in writing how my intake and exhaust blew the compression on my engine, and he said they don't have to, it's up to me to prove my parts didn't do it. So when I get my car back today I am gonna shove the Magnuson Moss Act up his ass.
lol
We have to prove it? shove that Magnuson Moss act up to his ass !
Seriously speaking, intakes I understand, but CAT back !?!? Come the hell on. Why dont they blame the roads ? blame the weather ? hell blame god for giving humans so many problems !
Its just sad that they keep paying minimum wage, all they can hire are ppl cant even finish their Junior high school.
Im with u bose, if u're in nyc or anywhere near, I will even go with you just to piss them off. jeeze
2k4_8 01-18-2008, 11:16 AM Great...bountiful mazda is my dealer too...makes me real confident....
Good luck with that! I hope they do you right on this!
Get this, so I picked up my car and the service manager said, "As far as what caused the problem, who knows but the fact that you have modded the car means you accept libility for anything that happens, it's in your warranty book." the warranty book says nothing NOTHING about aftermarket parts voiding the warranty. It only says somthing to the effect of, you may find parts that will fit your vehicle Mazda does not approved these parts and they will not be covered. the fine print disclaimer say the do not accept liability for any injury death or expenses that result from the installation of these parts. That right there says it has to proven that my parts caused the problem, but if they wanna play games I'm calling AEM and greddy today to see if I can get a letter from them stating thier parts do not adversly affect my engine. I wonder what they will say if I can prove my parts didn't do it.
I think you are doing it all wrong - just get a copy of the Mag Act; and tell the service manager who is not sure what is wrong - that his "unsureness" just got you a new engine.
secret8gent 01-18-2008, 12:03 PM hey, have you done a compression check (for real)? what are the numbers?
I know you say the dealer said you had no compression but that could be BS.
I wouldn't say your engine is dead until you have at least that much info in hand.
Have you confirmed X-times that you did re-wire the coils and plugs correctly? (coil side harnesses and plug wires)
The numbers are definatly low I had another dealer verify the compression, both rotors, numbers were almost identical, 6.3, 6.4, 6.7. somthing like that I don't have the paper in front of me.
Kane your right I fell like I have. Today I'm going back to the dealership to speak with the owner/gm, with a copy of the act, and just state 'hey, these are my rights you have to do this or we go to court. plain and simple.'
Sounds good - be nice; since no one likes a jackass; but the rules are pretty clear cut.
SRrx-8JC 01-21-2008, 12:52 PM Hey Bose did your car make a deep tone and then stall or did the cel light just flash, stay on and your car still ran? I think I have the same problem, I also pulled the codes I had 2 running too lean codes and misfire on cylinder 2. I am still tryin to figure out what is wrg with mine....good luck buddy
I agree the law is pretty clear where reponsibility lies.
But to answer your question. I have exhaust so it's always deep, but it wasn't any deeper than normal, she's never stalled, I was parked rev'ed it up and the light flashed 8-10 times then solid, she has run the same since I got her before the cel and after the cel came along, it feels the same. All I can say if I learned anything from this is if your taking it to the dealer, unless you have a mod friendly service manager, you need to put the stock parts in, it's not worth the hassle of being denied.
SRrx-8JC 01-21-2008, 01:50 PM Yea this weekend I am putting on all the stock parts, I think my engine is done too. I am running a compression test this weekend. I have a lot of stuff done to the car so I have my work cut out for me. Yea I have no cat and a Greddy exhaust so mine is deep too, you would notice this sound, mine happen on the highway when I downshifted and my car jus said F-you and then died.....well keep us posted man I have already been in fights with the dealership so I feel your pain....good luck bro.
nmarz77 01-21-2008, 02:06 PM I hate when dealerships are stupid ass-clowns about replacing things with aftermarket parts on it. Why a dealership would want to pass up a chance to make easy money is beyond me. Maybe they are hoping you will pay out of pocket so they get time and a half for labor? So much easier and less of a headache for them to just replace the engine under warranty than fight the consumer and try to rip them off for a few more bucks. Some dealerships are real dumb asses and then they wonder why their CSI's come back so f'ing shitty every quarter.
well I may be completely screwed, after talking to the district manager and Mazda technical hot line BOTH have denied warranty citing my aftermarket parts 'may have cause the problem' I'm told they are the only two that has actual say on the coverage once they have spoken that's it. I asked them to write a letter as to why they are dening warranty, they haven't faxed it yet. What do I do now? Get a lawyer to contact them, bite the bullet and get it fixed, basically am I really screwed or is there another route I can take to get this resolved.
nmarz77 01-22-2008, 02:44 PM I would go higher up and also find a lawyer that deals with auto lemon law bs.
Well spoke to the owner of the dealership, he said the reason they denied warranty is due to a clogged cat, took it to Master Muffler to have it verified to see if they are full of it or not. Well they are full of it, nothing wrong with the exhaust or the cat, they said I have to prove it wasn't my parts here they go. They can't say anything about the intake or they would be saying the Mazdaspeed intake is bad for the car. I think I have them by the balls now.
hagar852 01-25-2008, 02:41 PM Well spoke to the owner of the dealership, he said the reason they denied warranty is due to a clogged cat, took it to Master Muffler to have it verified to see if they are full of it or not. Well they are full of it, nothing wrong with the exhaust or the cat, they said I have to prove it wasn't my parts here they go. They can't say anything about the intake or they would be saying the Mazdaspeed intake is bad for the car. I think I have them by the balls now.
I don't know about the lemon law in your neck of the woods but in RI.. The dealer has to prove that it was the part that caused the malfunction... Not you!!
Huey52 01-25-2008, 02:43 PM btw: why this is critical to resolve:
"Wankel engines are very sensitive to misfires since the engine will lose momentum from the lost stroke and get slammed back into movement from the next chamber firing. Care of the ignition system is of utmost importance to avoid the problem."
lemon laws only apply to new cars though.
nycgps 01-25-2008, 03:57 PM Well spoke to the owner of the dealership, he said the reason they denied warranty is due to a clogged cat, took it to Master Muffler to have it verified to see if they are full of it or not. Well they are full of it, nothing wrong with the exhaust or the cat, they said I have to prove it wasn't my parts here they go. They can't say anything about the intake or they would be saying the Mazdaspeed intake is bad for the car. I think I have them by the balls now.
You got them already.
Its easy just tell them that Mazdaspeed intake is the Rebadged version of AEM. in the other words, Mazda PAID AEM to sell them their intake, but instead of AEM's names they put Mazdaspeed on it.
And why would they give people shit about AEM and not Mazdaspeed. if this thing goes up to court they will lose for sure.
About the Exhaust part, clogged? isnt it super easy to tell if its clogged? EVEN its clogged, what kind of bullshit is a *more free flowing exhuast* will cause a cat to fail faster than a more restricted one ?
Seriously Mazda should stop hiring people who cant even finish high school.
^^^Agreed, even if the cat had clogged it would be cause the engine is messed up, supercats don't just crumble and turn into a cork. they are screwed they shot themselves in the foot now I can't wait to get this over with.
BTW is that a double big mac? I have been meaning to ask.
nycgps 01-26-2008, 12:27 PM ^^^Agreed, even if the cat had clogged it would be cause the engine is messed up, supercats don't just crumble and turn into a cork. they are screwed they shot themselves in the foot now I can't wait to get this over with.
dealerships love to put BS on customers, well, *Typical* customers that is. They always have a big ass sign put up around the service department stating some *diamond packages* including *10% discount on parts value up to 700*, I was like LOL !!!!
but most of us are not the dumbasses that they're looking for, too bad, they can save their bs for someone else.
Just wait, they will fix urs.
P.S. : Nope, thats not double big mac, is called MegaMac, a *Japan only* product. I tried one when I was in Tokyo couple months ago. At first I was like hmm lets check out and see what kind of crap they sell in McDonaldos in Japan, then I saw this *MegaMac* thing I was like wtf? so I got one. Shit is huge ! shared it with my gf. Oh, they also have McPork too LOL !
HiTMaNN 01-26-2008, 03:18 PM That is good to hear bose that you got them screwed. I love how both the DSM and the shop manager claim they are the final decision. If they try and dick and tom you take it MNAO and start a shit storm. I am real good at doing that, IMO I don't think you will need a lawyer to win this one.
That shit looks bad ass even though I more of a Wendy's person then a McDonalds person.
Cody Red 01-26-2008, 09:22 PM wow, i'm having this problem too.
I didn't want to make a thread of it after seeing this one so hopefully if by describing everything going on, maybe i'll still get feedback (sorry OP)
'bout two weeks ago i couldn't pull after 4-4.5k without it hesitating like crazy (i replaced coils about a month before this).
I put in new plugs about 5 hours ago, did some pulls and it's not AS bad, but at 4.5-5k is does a hard misfire/jerk/hesitation...sluggish acceleration up to 7, then from 7 i get power like crazy, then another hard misfire/jerk/hesitation at 8k.
the plugs were replaced back in the summer because they kept popping off. maybe i crossed one of the plug wires when doing the coils? I would think it would have been obvious then, unless not? just in case, when looking at all four coil packs, in order from left to right, which is which? LTLT or TLTL
also, i have a hi-flow cat from SR Motorsports, i have about 15k miles on it. I remember reading in another thread that a lot of earlier produced hi-flo cats were going out after so long as well. thoughts? i still have the oem, i wanna just go ahead and get the SRs cut and made into test pipe.
any info will be great. i'll be reseting the ecu soon as well.
nycgps 01-26-2008, 09:45 PM That shit looks bad ass even though I more of a Wendy's person then a McDonalds person.
I like wendy's stuff more too. Hardly have Mcdonalds. but u know when u are so far away you might want try their *local* version of something u know. :)
The order should be LTLT.
but u better make sure you plug the plug wire to the right spark plugs too.
Put it back to stock and bring it in
LionZoo 01-26-2008, 11:48 PM What I do is replace one plug at a time; therefore it's impossible to get it mixed up as there's only one place for the plug/wire to go. Also, if you're doing the work yourself, did you use dielectric grease?
swoope 01-27-2008, 12:30 AM wow, i'm having this problem too.
cody,
pull the cat and look in it.. if it is bad it is obvious..
beers :beer:
Cody Red 01-27-2008, 01:41 AM The order should be LTLT.
well that's the thing, there's actually a long story about that (swoope knows). i'll have to see what I can do about doing that though...geez, "compression tests are like age tests" my friend tells me, "you'll always be worried about the results."
something like that. i'll pull the cat asap, weather sucks hard though.
swoope 01-27-2008, 01:44 AM well that's the thing, there's actually a long story about that (swoope knows). i'll have to see what I can do about doing that though...geez, "compression tests are like age tests" my friend tells me, "you'll always be worried about the results."
i will be in town next weekend .. i might have fri afternoon to myself.. let me know if you find anything out.
if not i might pull the scanaylzer cables out of my car and see what we can find..
beers :beer:
Cody Red 01-27-2008, 02:06 PM i will be in town next weekend .. i might have fri afternoon to myself.. let me know if you find anything out.
beers :beer:
lmk, my brother will be down that weekend so it will be tough to find some time. you have my number or pm me.
any other suggestions? idk if there'd be any, but it doesn't hurt to ask.
swoope 01-27-2008, 02:57 PM lmk, my brother will be down that weekend so it will be tough to find some time. you have my number or pm me.
are they the new updated coils you put in????
any cel at all, flashing or otherwise?
beers :beer:
Razz1 01-27-2008, 03:10 PM You got them already.
And the CAT back exhaust is just a muffler. State and Federal law allows you to choose any manufacturere for a muffler.
You have to fight for your rights.
nycgps 01-27-2008, 07:49 PM And the CAT back exhaust is just a muffler. State and Federal law allows you to choose any manufacturere for a muffler.
I know, thats why I said (for example) its bullshit for dealerships to give people crap about AEM intake while Mazdaspeed is the *rebadged version* of the AEM.
Exhaust ... lol its after the cat, and more free flowing, how the FUXK a more free flowing exhaust can fudge a CAT up even faster than the Stock, more restricted one.
Dealerships .... sux these days ...
dothackRAVE 01-27-2008, 08:01 PM Dealerships like to bullshit you out of your money. They finished highschool, and they know they get more $$$ if they bullshit their way into your wallet.
Seriously. I got charged for a powersteering fluid change when there isn't fucking powersteering fluid to change. I told them to save their BS for someone else, and now I am adamant about never going to dealerships for maintenance.
Razz1 01-27-2008, 10:19 PM ^ you should have copied your reciept and sent it to Mazda Headquarters.
Mazurfer 01-27-2008, 10:22 PM Yeah.....that was a real cute trick.........I would've faxed that to HQ in an instant!
nycgps 01-27-2008, 11:01 PM Dealerships like to bullshit you out of your money. They finished highschool, and they know they get more $$$ if they bullshit their way into your wallet.
lol powersteering fluid change ..... rofl !!!!!!!!
Cody Red 01-27-2008, 11:52 PM are they the new updated coils you put in????
beers :beer:
coils are the lastest.
i've been driving around with cel, on and off on some days, but i believe my front o2 censor is bad. i will take a look when pulling the cat if i get a chance.
when i drove with the new plugs, i did a pull in 2nd (with all what was described before) the CEL started flashing. so I turned into a median to go back, the CEL went away. I pulled again just to verify the points of misfire/sluggish feel the CEL started to blink again when turning into another median.
geez, i hate '04 already.
nycgps 01-27-2008, 11:58 PM coils are the lastest.
misfire happened to me a *while* ago. twice, of course CEL stayed on.
then I just ignore it and keep driving it like nutz .... never came back after that, yet.
swoope 01-28-2008, 12:03 AM coils are the lastest.
i guess you dont know what the cel is?? not the blinking one.. you might be having fun with what i just went through, but one of the things is the front o2 sensor..
that was not my issue. btw, look at the plug wires close.. where the connection is.. i can send you a set if needed.
beers :beer:
Cody Red 01-28-2008, 02:26 AM i guess you dont know what the cel is?? not the blinking one.. you might be having fun with what i just went through, but one of the things is the front o2 sensor..
beers :beer:
i just examine them thoroughly?
i have a set of MSD wires that i bought from SR about a year and a half ago. I had them on for a while, but took them off because it threw a CEL (but it was just a misfire, and yeah). Should I give the MSD wires a chance and just take pics of the oem plugs and post here?
swoope 01-28-2008, 02:41 AM i just examine them thoroughly?
look at the connectors the attach to the plugs for corrosion... and make sure they are in the coils tight.. the front lower one tends to come loose.
i would compare the wires and see if you can see something odd...
but with new plugs and coils.. that is the odd man out..
also pull the room fuse to reset the ecu...
beers :beer:
Cody Red 01-28-2008, 03:53 AM look at the connectors the attach to the plugs for corrosion... and make sure they are in the coils tight.. the front lower one tends to come loose.
beers :beer:
there was some corrosion on the plug(s). i'll post pics tomorrow and reset ecu.
so just pull the room fuse, reset and install again?
swoope 01-28-2008, 03:57 AM there was some corrosion on the plug(s). i'll post pics tomorrow and reset ecu.
pull fuse,
step on brake..
send the photos to my email.. i think you have it..
if not send me a pm.
beers :beer:
Cody Red 01-28-2008, 07:59 PM pull fuse,
step on brake..
beers :beer:
pulled room, reset, no more misfire.
you still want pics of the wires?
swoope 01-28-2008, 08:05 PM pulled room, reset, no more misfire.
not if the end connections look good...
btw, after the fuse pull the idle is going to be funny for a couple of drive cycles..
beers :beer:
Cody Red 01-28-2008, 09:30 PM not if the end connections look good...
beers :beer:
yeah, it was still dropping to 500rpm after driving ten miles that included 3 3rd gear pulls.
thanks scott, and everyone else + OP for letting me borrow his thread.
swoope 01-28-2008, 09:46 PM yeah, it was still dropping to 500rpm after driving ten miles that included 3 3rd gear pulls.
yep,
no problem.. i like the second to third gear pulls..
beers :beer:
CnnmnSchnpps 01-28-2008, 11:29 PM P.S. : Nope, thats not double big mac, is called MegaMac, a *Japan only* product.
They used to have it in France as well for a while.. I think they might have even had a bigger one...
Then I was in Tokyo over New Years they had a big mac with egg in it.. Crazy :lol2:
bose - so what's up? any news from the clowns at Mazda?
HiTMaNN 01-28-2008, 11:48 PM They used to have it in France as well for a while.. I think they might have even had a bigger one...
India all McDonalds products are served with Mutton because Hindus don't eat beef
CnnmnSchnpps 01-28-2008, 11:59 PM ^ Cool. I might have a chance to go out to India for work at some point, but I'm a little scared..
Oh yes here's the lastest gem from the lead tech. He said that my cat wasn't clogged he used the wrong term, he said that the 2nd o2 sensor readings are 'off' what they normally look for so my ecu adjusted the air intake and fuel consumption, so I altered the vehicle, at this point I interrupt and ask so that causes seals to blow, his response was no, we're not sure what made the seals go bad. Then I refer to Mag Moss you guys have to prove what about my parts caused the failure, he says no you have to prove they didn't cause failure. Well my intake is the same as the one you sell with a mazdaspeed sticker, my cat is in perfect condition I have a muffler shop that can vouch and my exhaust is more free flowing they couldn't cause this. He says well how do you explain the reading from the o2 sensor look we can go back and forth on this all day fact is your motor is bad and it's not covered cause of the parts. So they admit they have no clue what caused the problem, I have proved my parts are fine and still I get no help. Next step...I guess court or somthing. What I don't get is my car still runs fine no power loss idk, I still wonder if the compression is even bad maybe they don't know how to check it. :banghead: :banghead: :banghead:
nmarz77 01-29-2008, 02:20 PM They sound like idiots over there. Maybe you should get a compression check somewhere else.
CnnmnSchnpps 01-29-2008, 02:57 PM ^ Make sure they warmed it up properly before doing the compression check? Maybe find a rotary shop to do it for you so you're 100% sure it's done properly.
Here's another good piece on the MM Act http://www.knfilters.com/warrantyletter.htm
nycgps 01-29-2008, 04:34 PM Oh yes here's the lastest gem from the lead tech. He said that my cat wasn't clogged he used the wrong term, he said that the 2nd o2 sensor readings are 'off' what they normally look for so my ecu adjusted the air intake and fuel consumption, so I altered the vehicle, at this point I interrupt and ask so that causes seals to blow, his response was no, we're not sure what made the seals go bad. Then I refer to Mag Moss you guys have to prove what about my parts caused the failure, he says no you have to prove they didn't cause failure. Well my intake is the same as the one you sell with a mazdaspeed sticker, my cat is in perfect condition I have a muffler shop that can vouch and my exhaust is more free flowing they couldn't cause this. He says well how do you explain the reading from the o2 sensor look we can go back and forth on this all day fact is your motor is bad and it's not covered cause of the parts. So they admit they have no clue what caused the problem, I have proved my parts are fine and still I get no help. Next step...I guess court or somthing. What I don't get is my car still runs fine no power loss idk, I still wonder if the compression is even bad maybe they don't know how to check it. :banghead: :banghead: :banghead:
They're idiots. Whats the dealership's number and what is the lead tech's name ?
Maybe I should start giving them a call, I want to make sure that they understand english and re-read what it saids on the Moss Act. How about a file to small claims court sound to them and/or Mazda ?
What did Mazda say now ? Have you give them a call recently ?
and they ask how can you explain the motors went bad? How fuxking stupid can they get? Shit happens? Tell them, Why some people never smoke, never drink, Eat right and excerise everyday, Going to bed in the right time, never messed around can still get Cancer? Ask them that, Yeah I wanna them to give me an explaination in that too.
I can explain that, cuz Shit FUCKING HAPPENS EVERY DAY !
I dont understand these people, if they are fuxking lazy and dont want to do shit, why didnt they study hard back in school and get a more decent job ? They're not even that low pay, being a dealership tech can get them what, 15-20 bux an hour? and they're still lazy as fuxk. god!
Seriously, can you go to another dealership by any chance? cuz this one u're going right now are nothing but a bunch of fuxk tards.
CnnmnSchnpps 01-29-2008, 04:38 PM If you're talking about engine replacement, you are likely over the limit for small claims
nycgps 01-29-2008, 04:44 PM If you're talking about engine replacement, you are likely over the limit for small claims
In NYC I think the limit is about 3000 dollars for each case.
Im not even sure if they did the compression right in the first place. Cuz that place sound like a wonderland for lazy crooks
Mazurfer 01-29-2008, 09:26 PM ^+1 million
nycgps 01-30-2008, 12:15 AM ^+1 million
if its 1 million, Im *pretty* sure that the small claims court will be pack everyday from 8 to 5 :lol: :lol: :lol: :lol:
Im almost positive they didn't do the test right. cause my compression numbers they gave me are like 6.4, 6.3, 6.5. From everyone I have talked to who has low compression their cars either won't start and if they do start they don't run well at all, loss of power and such. My car feels no different at all, she starts, runs, idles well everything seems great, cel has been gone for 2 weeks. I was reading on how to check rotory compression you need a specialized tester, when I asked the dealer how they did it, they said same as a piston engine!
Yeah I believe the limit in small claims is 3 grand.
Dennis is the tech's name, Bountiful Mazda is the dealer 801-397-2277.
CnnmnSchnpps 01-30-2008, 11:16 AM A couple things:
- Did they give you the RPM at which the test was run?
- If they did it with a piston compression checker they wouldn't have been able to give you 3 separate numbers...
nmarz77 01-30-2008, 12:12 PM Maybe you should do a compression test yourself. I know it's not as accurate as the "special" tester mazda uses, but it's worth a try.
http://www.banzai-racing.com/compression_test.htm
A couple things:
They said 200 rpm, and IDK what they did really the more I talk to them the more I think they didnt even do one.
nmarz thanks I wanna do that where do I purchase that compression valve? checker/autozone I assume.
nycgps 01-30-2008, 12:22 PM They said 200 rpm, and IDK what they did really the more I talk to them the more I think they didnt even do one.
lol ? exactly 200 rpm ?
I dont think they didnt do it right, they can do it at 200, but meh, it really sounds fishy.
Can you bring your car to anywhere else ?
Yeah I can take it to another stealer, but this dealer has flagged my vin# so warranty from another dealer probably won't happen.
nmarz77 01-30-2008, 12:40 PM nmarz thanks I wanna do that where do I purchase that compression valve? checker/autozone I assume.
Yeah you should be able to pick one up from autozone, not sure of the quality though. For a "decent" quality one at a fair price you could also pick up a Craftsman one from Sears.
CnnmnSchnpps 01-30-2008, 01:56 PM They said 200 rpm, and IDK what they did really the more I talk to them the more I think they didnt even do one.
From what I've read on the forums, you either get 250RPM (old starter) or 320RPM (upgraded starter), +/- 5 or so. If they're telling you 200 exactly, something's up. Mine was at 320, and i got 8, 7.9, 7.9 on both rotors, which is pretty terrible.. Dealer says "a-ok" :banghead:
I'm going to get a gauge and do the test myself just to know it's done right. If I still get the same numbers, I'm going to court, tired of the runaround.
You can get one from Sears or most auto parts places... You just need to make a little modification to the standard piston ones...
MazdaManiac 01-30-2008, 02:06 PM FWIW, I'm on the old starter and my compression test numbers come in at 230 RPM.
nycgps 01-30-2008, 02:09 PM Im almost positive they didn't do the test right. cause my compression numbers they gave me are like 6.4, 6.3, 6.5. From everyone I have talked to who has low compression their cars either won't start and if they do start they don't run well at all, loss of power and such. My car feels no different at all, she starts, runs, idles well everything seems great, cel has been gone for 2 weeks. I was reading on how to check rotory compression you need a specialized tester, when I asked the dealer how they did it, they said same as a piston engine!
I tried to call but no one is picking up for some reason. Maybe my cell phone sucks calls just cant get thru (trust me it happens, fuxking AT&T/Cingular), I even got calls from someone I dont know when the caller ID shows is from my father. I was like wtf since when did my father speaks spanish ?
Thats why I said it sounds fishy, 200 rpm ? lol wow, they SURE have NO IDEA how to do the compression test right. 200 rpm is possible. but they really have no clue what they're tlaking about. Lemme find u the service manual part ... hold on
nycgps 01-30-2008, 02:13 PM http://www.rx8club.com/attachment.php?attachmentid=114493&stc=1&d=1201720427
Here you go. Try to tell them to Crank the thing again, they're probably lazy about the removing spark plugs part.
CnnmnSchnpps 01-30-2008, 02:43 PM ^ Oh, and good luck getting them to understand that chart... Although if you really are cranking at 200 rpm that will work to your advantage
nycgps 01-30-2008, 02:51 PM ^ Oh, and good luck getting them to understand that chart... Although if you really are cranking at 200 rpm that will work to your advantage
The graph looks simple to me. :lol:
College helps maybe, but Do they even need college to understand that graph ? :lol: dealership these days .... are really .... something.
CnnmnSchnpps 01-30-2008, 03:12 PM Let's not go there :lol:
