Removing the damn molex
Old Jan 9, 2008 | 08:14 PM
maverick02's Avatar
Hi guys.. I've read the forbidden guide and other tips but I just cannot remove the driver sides molex.. im trying to pry the thing out and half of it is stuck inside. Tips?
Old Jan 9, 2008 | 08:29 PM
maverick02's Avatar
Maybe the entire thing isnt supposed to come out? Do you have to separate the molex and half of it comes out through the interior and the other half through the door?
Old Jan 9, 2008 | 08:42 PM
maverick02's Avatar
Does this look right?
Old Jan 9, 2008 | 09:50 PM
WikkedOne's Avatar
Deals on wheels
I found it was easier to just remove the door to get good leverage to do run my wires through.. it's only 4 bolts.. and if you have a friend it's not that bad at all....
Old Jan 9, 2008 | 09:58 PM
maverick02's Avatar
wickkedone, can you tell me if the entire molex comes out or do you have to split it open and only side of the molex comes out?
Old Jan 9, 2008 | 10:01 PM
maverick02's Avatar
I'm thinking i have to stick a pick in and push on the lever as shown in the pic above to get the molex out, right?
Old Jan 10, 2008 | 03:04 PM
Juice's Avatar
I made some poos
I Pmed you. But yeah, the blue connector will disconnect the two halves of the molex. The rear half does come out all the way from the door. There isn't anything to hold it back once the connection is split. What I did was push the blue lever with a small screwdriver until it popped back. Then I pulled the front piece of the connector out. With the front part of the connector out, you can angle it down and get to the back half of the connector. There is a good amount of slack in the wiring, just make sure the rubber boot is rolled back as far as you can get it towards the door and you will have enough play to get it all out. This is definitely a complete pain in the *** but it can be done.
Racingjunkie
Sep 29, 2015 05:05 PM
FubarI33t
Sep 28, 2015 08:45 PM
xAgyex
Sep 28, 2015 08:54 AM
Learners_Permit
Sep 27, 2015 07:38 PM
