04 rx8 with some issues
Old Jan 9, 2008 | 06:40 PM
kevinD1226's Avatar
like the tittle says i have an 04 rx8 with 50,500 miles on it.. now my issue is my idle will go from 800-900 and sometimes it seems to drop a little below 800 and i get this annoying vibration feel the shifter shakes like a b*tch too so im sure its not helping ive searched the forums and i found several issues but most of them the issue included power loss... the thing is i dont get power loss the car pulls pretty good, i have no cels, i changed out the plugs about 6k miles ago along with the dealer changed my motormounts as well.. since i have no power loss what do u guys suggest i do?? i believe at 50,500 the warrenty is up.. ive taken it to the dealer for it before and they say its normal but from what i read the rotary engine is suposed to run very smooth
Old Jan 9, 2008 | 06:54 PM
The thing is that you did not search enough
the thing is that your motor mounts are bad
the thing is that you're out of your warranty already
The thing is that you have to buy a new set on your own.
Old Jan 9, 2008 | 07:13 PM
kevinD1226's Avatar
dude the motor mounts were replaced less than 6k miles ago
Old Jan 9, 2008 | 07:14 PM
kevinD1226's Avatar
trust me i searched.. if it were bad coils id have power loss, bad mounts would be vibration but they were literally replaced around 45k miles so that just cant be it, plugs replaced,maf sensor cleaned looked fine anyways.. i just dont know what else to check
Old Jan 9, 2008 | 07:22 PM
dont dude me dude.
who said it cannot fail after 6 K miles ?
plugs replaced by what and when ? yourself ? are you talking about the recall one ?
Old Jan 9, 2008 | 07:30 PM
kevinD1226's Avatar
whats ur problem? if ur pissed i didnt search enough then dont bother readin this thread.. just let it go man
Old Jan 9, 2008 | 07:31 PM
kevinD1226's Avatar
i changed out the spark plugs myself...
Old Jan 9, 2008 | 07:35 PM
bsteimel's Avatar
Nice !!!
Thats how he is with everyone just relax, he does have some valuable information. I would suspect motor mounts to as I had them replaced recently and it calmed down some vibration and made shifting easier. Maybe they could have been faulty and did fail after 6k miles. Although it revving funny might be some type of other problem. Maybe someone here as some experience. How long as it been happening? Could it be simply a tank of bad gas? Is the car at operating temperature when this happens or cold?
Old Jan 9, 2008 | 07:54 PM
kevinD1226's Avatar
when it happens the car is at operating temperature... i also read its maybe signs of a bad cat but i just did a rb catback with rp midpipe with highflow cat so thats not the issue either.... i never replaced the coils or spark plug wires and i think they might be original but im not sure the idle jumping from 800-900 would be cause by it
Old Jan 9, 2008 | 08:17 PM
kevinD1226's Avatar
are the 04s powertrain warrenty 6yrs/60k miles if so ill just try the dealer
Old Jan 9, 2008 | 08:22 PM
invasion08's Avatar
its 5yrs 60k
Old Jan 9, 2008 | 08:57 PM
trust me if im pissed I wouldnt sound like that. Thats already my *nice* tone to noobs
reason I ask is that, it IS POSSIBLE that stock mounts fail prematurely.
if you're positive that your mount is not the issue. whats next?
plugs? yes you did change it yourself but when ?
what about coils?
Powertrain warranty for 04 and 05 has been extended to 60 months or 60K miles, whichever comes first.
and dont forget powertrain warranty does NOT cover motor mounts. so you might want to keep that in mind.
Do you know what Flash level you're on ?
Old Jan 9, 2008 | 09:09 PM
Could be neutral switch.
Do a search on surge or idle surge
https://www.rx8club.com/showthread.p...ght=idle+surge
there's another thread around some where that pinned it to a differnt problem.
Old Jan 10, 2008 | 06:30 AM
max5roadster's Avatar
INDY RX8 CLUB - Officer
NYC-
The mounts are listed as part of the covered items in the recall extension letter...
Old Jan 10, 2008 | 07:00 AM
dtahbk's Avatar
I had the same problems as you are having. I took the RX8 to the dealer and they replaced the motor mounts, two ignitions coils and wires. Plus they updated my ECM and replaced my MAF sensor. I thought my MAF sensor was fine. They said the sensor was the reason for it idling rough. The car runs like new now.
Old Jan 10, 2008 | 07:15 AM
enforcer's Avatar
Trust me KevinD...you don't want to see his dark side...!
Old Jan 10, 2008 | 08:14 AM
Originally Posted by max5roadster
NYC-
Its only covered if thats the *cause of failure*
in MOST CASES, they wont cover it. Trust me on that one.
Old Jan 10, 2008 | 08:17 AM
brrawwwwwarRRRRRRR !!!!!!
Old Jan 10, 2008 | 03:31 PM
kevinD1226's Avatar
well i apologize for beeing a bit aggressive... the way i read it i thought he was beeing rude, but if thats the way he is then its all good
Old Jan 11, 2008 | 04:09 AM
make sure spark plugs are tight!!!!!!
check the plug wires.
coils..
and just for fun, if you have just reset with a battery pull..
search ac amplifier.
Old Jan 11, 2008 | 04:51 PM
kevinD1226's Avatar
now i have a cel so i went to autozone today to check the cel and they dont do it in the rain and i called the dealer to see if i still had warrenty he said 04s are only 5yrs/50k miles and the 5yr/60k mile is only on the stuff like the ecu.. so once i have the engine light code ill search on the forum to see what it could possibly be.. im hoping its an easy fix
Old Jan 11, 2008 | 05:58 PM
Old Rotor's Avatar
Here is what is covered on the warranty, print and show your dealer.
http://www.finishlineperformance.com.../pdf/ad-18.pdf
ei8ht
Aug 21, 2017 09:08 AM
learningdriver
Aug 8, 2015 06:55 AM
SIllver
Aug 1, 2015 07:34 PM
marc2820
Jul 26, 2015 10:47 PM
Belalnabi
Jul 17, 2015 07:48 PM
