Coolant
Old Jan 9, 2008 | 04:48 PM
Temptone's Avatar
Coolant
What do you guys use for year-round coolant...Northeast U.S.? / PA Bucks County ?
My coolant light stays on a little longer (10 or 15 seconds only, Never when driving)when I start cold and I thought maybe it needs some juice.
I blew my RX7 seals and warped the head because the radiator hose blew and I drove a half a mile to get to a station. I don't want to have anything go wrong on the 8.
Old Jan 9, 2008 | 11:23 PM
ken-x8's Avatar
If there's a FL22 label on (or near) your radiator cap, that's a Mazda-brand 50/50 mix. You should top off with that. Supposed 10 year life.
Otherwise, just get a name brand glycol antifreeze and mix 50/50 yourself. You can buy stuff pre-diluted to 50/50, which is convenient if you just need a little.
You can see if your coolant level is OK by looking at the reservoir.
Ken
Old Jan 9, 2008 | 11:24 PM
Ken
I wonder how much do these *FL22* cost a gallon.
Ken do u know how much they are ?
Old Jan 9, 2008 | 11:34 PM
turborx8's Avatar
Boost 4 Life
Dont fill your reservoir all the way.
You need about 2 inches of play because when the car wams up the level will rise.
Old Jan 10, 2008 | 12:09 AM
delhi's Avatar
Grand Chancellor
I picked up a 4L jug of FL22 for $15.xx. Make sure you read the label. Most Mazda dealers carry the regular stuff.
Old Jan 10, 2008 | 04:21 PM
ProCharger GT's Avatar
a/s/l/n00dz?
All the cool kids use water wetter...lol
https://www.rx8club.com/series-i-tech-garage-22/coolant-boiling-question-124981/
Old Jan 11, 2008 | 04:26 PM
F22C1's Avatar
I got a side question related to this topic...
if the water pump at high operation causes cavitation and some theorize this causes air gurgling noise in my heater core, I'm assuming I got air in the system correct? I'm just wondering why is my reservoir is still nearly full then?
Wouldn't the fluctuation between hot and cold, levels rising and lowering, remove this air eventually?
And why was the sound not there to begin with when brand new?
I'd hate to think of doing a flush when that stuff is supposed to be good for 10 years.
Old Jan 11, 2008 | 05:09 PM
DeViLbOi's Avatar
The devil made me do it
If you have a large pocket of air in the system the vaccum will fail and it will not pull fluid from your resevoir. You should remove your radiator cap and run the car for a while with the heater on...this should remove the bubbles as the cap is at the highest point in the system. Top off if needed and put the cap back on.
Old Jan 12, 2008 | 09:45 AM
ZoomZoom28's Avatar
$13.99 a gallon for FL22. Make sure it's "Extended Life Coolant". The first dealer I went to try to sell me the "Long Life Coolant".
Luiss7
54
Aug 20, 2019 08:56 AM
Azki23
Jun 27, 2018 03:48 PM
drlubell
Sep 26, 2015 11:58 PM
Rx8_412
Sep 24, 2015 08:51 PM
