R888
01-08-2008, 10:36 PM
Should I refill the coolant or change it to redline or royal purple?
Or is it because of the water pump?
View Full Version : Coolant light always on when in high RPM 5500 / 6000 R888 01-08-2008, 10:36 PM Should I refill the coolant or change it to redline or royal purple? Or is it because of the water pump? __________________ dannobre 01-08-2008, 11:20 PM Fill coolant.....watch for a few days to see if it keeps going down...if it does..could be leak....water pump =easy fix, hose=easy fix...into engine with white smoke=hard fix :D: nycgps 01-09-2008, 12:13 AM Fill coolant.....watch for a few days to see if it keeps going down...if it does..could be leak....water pump =easy fix, hose=easy fix...into engine with white smoke=hard fix :D: engine with white smoke = impossible to fix unless you take your engine out and apart :bowdown: :bowdown: :bowdown: to R888 : What about After 6000 rpm ? does it stays on or ? and theres no such thing as *coolant* from RP or RL, they sell something that *lowers* the surface temp, but thats it. You can just mix them with coolants, any major brand is good. what I have now is Prestone 50/50 Mix it down to about 40/60 (I add a bit more of distilled water) + Redline's water wetter. Of which, Tomorrow Im going to drain everything out and This time is Peak 50/50 with Royal Purple's Ice. why no Distilled water this time? cuz its freaking cold this coming week so ... if I need them I will just add a bit of distilled water no biggy. Startl_Respons 01-09-2008, 01:57 AM I would fill with 50/50 premixed coolant (that you don't have to add distilled water) and observe for a few days. Look for puddle underneath car the next day. Raise front end and get underneath and look at area around water pump to see if their is any green liquid anywhere under the car. LionZoo 01-09-2008, 08:23 PM There is a history of defective coolant level sensors for the RX-8. I know a few guys here have had the light come on during hard driving even though their level is good. I've had it happen to me a few times, but I only see it under pretty constant g loading. R888 01-10-2008, 07:57 PM shit what should I do? nycgps 01-10-2008, 10:35 PM Nothing really. if you worry, fill it up with 50/50 to about 1/2 of the coolant reservoir. Its hard to read the Max line I know, but if you look inside, you'll see the little gap in there. Anyway just fill it to about 1/2, drive it around see if there are leaks or lost of power, it not then, u're ok. LionZoo 01-10-2008, 11:24 PM Just have a good idea of your coolant level and don't trust the sensor light, or take it to the dealer and get the sensor replaced. Mazurfer 01-10-2008, 11:27 PM Just have a good idea of your coolant level and don't trust the sensor light, or take it to the dealer and get the sensor replaced. If I remember correctly..............the sensor is molded into the overflow tank or some shit, so you have to get another tank.....right? Anyway.....if you are under warranty then it won't matter....go get one. See this thread about halfway down, I did remember correctly. http://www.rx8club.com/showthread.php?t=118947&highlight=coolant+light nycgps 01-10-2008, 11:51 PM If I remember correctly..............the sensor is molded into the overflow tank or some shit, so you have to get another tank.....right? Anyway.....if you are under warranty then it won't matter....go get one. See this thread about halfway down, I did remember correctly. http://www.rx8club.com/showthread.php?t=118947&highlight=coolant+light yep you're right, the sensor is part of the bottle. you have to replace the whole thing to get it right. But to me, I mean, the sensor is nothing but a *on/off* sensor. if it comes on its already too low. so just keep an eye on your coolant level, check regularly, u'll be fine. Mazurfer 01-11-2008, 10:02 AM yep you're right, the sensor is part of the bottle. you have to replace the whole thing to get it right. But to me, I mean, the sensor is nothing but a *on/off* sensor. if it comes on its already too low. so just keep an eye on your coolant level, check regularly, u'll be fine. I agree...................but if mine goes out, since money isn't a concern, I'd probably get the bottle. :) Then I would of course take the old one apart and see what's up with it and have as a spare. nycgps 01-11-2008, 10:11 AM I agree...................but if mine goes out, since money isn't a concern, I'd probably get the bottle. :) Then I would of course take the old one apart and see what's up with it and have as a spare. as far as I know the sensor part is sealed into the bottle, there should be no going back if you take it apart :( Ahh well, let me go flush my coolant today :) R888 01-11-2008, 09:45 PM kool, thanks guys =) R888 03-21-2008, 06:37 PM lack of coolant is the reason after inspection. Thanks guys, LOL |
