spak plugs ??????
Old Jan 6, 2008 | 04:15 PM
dimitris_patrx8's Avatar
spak plugs ??????
hello!!!!! which is gonne a be the best choice for my stock 6gear mazda???? any spark with a little bit more power means WOrking better for my renesis? anu iridium or colder os somthing else? thaks a lot!!!!!!!
Old Jan 6, 2008 | 04:43 PM
expo1's Avatar
He's as bad as Can
Your choices on spark plugs are limited on the rx-8
either the stock ones or the RX-7's plugs. The RX-7 ones are cheaper and some members here use them without any issues. If your car is still under warranty I would stick with stock plugs. You can find them for $20.00 each at http://www.sparkplugs.com/
StealthTL's Avatar
Metatron
Nope - stick with stock - a spark plug ain't gonna do it.
S
Old Jan 6, 2008 | 05:11 PM
TrochoidMagic's Avatar
is adjusting valve lash
what would the benefits be with using rx-7 spark plugs? i don't see any. they would prolly run higher ohms and have worst flame propa...
for best ignition performance, you want everything to fire with the lowest resistance...so i would recommend just saving some money and getting some cheap magnecor 10mm wires. leave the stock plat plugs alone.
Old Jan 6, 2008 | 05:13 PM
chetrickerman's Avatar
i believe the 7 plugs are colder, and they are cheaper
Old Jan 6, 2008 | 07:25 PM
invasion08's Avatar
Go to www.autopartswarehouse.com for all 4 spark plugs are like 85 dollars and free shipping
Old Jan 6, 2008 | 07:30 PM
or you could go here
Old Jan 6, 2008 | 07:43 PM
invasion08's Avatar
yeah but why pay 109 plus shipping when you can get them for 85
Old Jan 6, 2008 | 07:45 PM
true. thats just where i bought them
Old Jan 6, 2008 | 08:17 PM
turborx8's Avatar
Boost 4 Life
DO NOT USE RX-7 PLUGS IN THE LEADING POSITIONS!!!
The only reason to use rx7 plugs would be to save money. They are 2mm longer so you will need to shim the plug.
Old Jan 7, 2008 | 12:04 AM
There are a few people who have tried Denso's. Only one has said they are great.
The others never responded to my Emails.
Old Jan 7, 2008 | 03:09 AM
Startl_Respons's Avatar
Don't forget Napa Auto Parts for about $23 each before tax. Be sure to call your local Napa to find out which store has them because most don't. They will search on their computer to find which store has them, which will probably be the local region distribution center. If it's too far from you, they will ship them to the store that is closest to you on the same day! Of course this is if you can't wait for mail-ordering.
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
WranglerFan
Aug 21, 2022 01:29 PM
Tweaked Tay
Sep 25, 2015 07:54 AM
iphil
Sep 21, 2015 10:49 PM
Vedivan1
Sep 18, 2015 12:39 PM
