Rotary Volumetric Efficiency Explained link
Old Jan 2, 2008 | 10:17 AM
mlx8's Avatar
Ran a search on "volumetric efficiency" ~ too many hits/threads to try to plow through to see if this has been posted before, but .... in case is hasn't, and for those who've any interest in stuff like this, I came across the following link while searching for some information on rotary's stuffed into Caterham / Lostus 7's
It's some one name "Miguel P" and, at least to me, seems very well written, researched and full of rotary data, so I'd thought I'd share the link:
http://ezinearticles.com/?Volumetric...ained&id=47639
for those interested. Hard to believe the author, Miguel P, wouldn't be on this site under one pseudonym or another.
If it's already been posted before, maybe one of the moderators can delete this, or provide the internal link to the thread on the Rx8Club site. 94% VE that's a pretty high number.
Still searching for more information on rotary powered light weight Caterham's or their ilk.
Happy New Year to everyone
Old Jan 2, 2008 | 11:08 AM
chetrickerman's Avatar
that is a very good write up, but according to everyone on here, rotary engines arent more efficient than pistion engines
Old Jan 2, 2008 | 11:43 AM
MazdaManiac's Avatar
That's not quite right.
Rotaries have a lower BSFC than piston motors because they are thermally inefficient.
However, their volumetric efficiency is quite high because of the relatively large ports.
I didn't get too far into that write-up (I'll do it later), but the Ve for the Renesis was already computed using actual MAF values by Hymee or one of the other Aussies, so its merely academic at this point.
Old Jan 2, 2008 | 12:05 PM
NgoRX8's Avatar
haha, i actually was looking through that page yesterday as well. what a coincidence.
Old Jan 2, 2008 | 12:13 PM
oh. what is BSFC again? how can you change the thermal efficiency?
Old Jan 2, 2008 | 12:17 PM
Brake Specific Fuel Consumption. Most piston engines are in the 60% range. Rotaries are around 50%.
You can't. Not directly, anyway. Its inherent in the design because of the shape of the combustion chambers, amongst other things.
Old Jan 2, 2008 | 12:47 PM
thats what they said. but rotaries have a higher VE than piston engines? why would the port sizes make a difference in the efficiency? i thought it would be the combustion chambers.
what about insulating the chambers more?
Old Jan 2, 2008 | 12:59 PM
PhillipM's Avatar
Because the large ports allow a large amount of mixture in for the size of the chamber, but because of the shape of the chamber and other problems with the rotary it doesn't extract as much of the power available from that mixture as a piston engine could.
Old Jan 2, 2008 | 01:08 PM
More air in.
Insulting them from what? Themselves?
Its inherent to the moving combustion chamber of the rotary that work is wasted.
Old Jan 2, 2008 | 01:22 PM
PhillipM's Avatar
You could possible help with thick ceramic coatings but whether that is both practical or viable is another matter.
Old Jan 2, 2008 | 01:45 PM
That would only address heat lost through the coolant jacket (can't really be done anyway - apex seals will want to see SIP, not ceramic.
Much of the loss is the movement/shape-shift of the combustion chamber itself.
Old Jan 2, 2008 | 02:13 PM
got it. im just throwing ideas out there
Old Oct 27, 2012 | 09:09 PM
BlackBird05's Avatar
Here's a heavy read on some attempts to use ceramic inside the rotary engine:
http://www.rotaryeng.net/Adiabatic-rotary.pdf
I think if you were to use ceramic plates and bolt them onto the side housings, that could be more viable than a thick ceramic coating.
Old Oct 28, 2012 | 02:50 AM
ShellDude's Avatar
weeeeeeeeee
Hello!
ASH8
General Automotive
2029
Apr 10, 2026 02:06 PM
Feffman
SE RX-8 Forum
Oct 7, 2015 06:58 AM
r-enzyme
Oct 1, 2015 01:27 AM
Feffman
RX-8 Racing
Sep 30, 2015 05:56 AM
