Nitrous install questions!
Old Jan 1, 2008 | 06:09 PM
8 Maniac's Avatar
Senior Member
I'm currently installing my zex kit and I've come along to the wiring portion of the install. I know I need to run the red wire through the fire wall but wasnt sure off the top of my head if there was a location which could be used stock to slide the wire through. If not, then where should I try to locate the wire? My other question is where it's best to get the power from? I know it needs 10 amps but is there an accessory slot in the fuse box I can use? Then the last question is where I'm supposed to tap for the throttle wire. Thanks in advance for the help
Old Jan 1, 2008 | 06:40 PM
WoodsOfGreenRx8's Avatar
Did you check CRH Nitrous thread? He might have covered some of this there? I don't know for sure.
Old Jan 1, 2008 | 06:43 PM
BDC's Avatar
BDC
BDC Motorsports
+1. Talk to Ray.
B
Old Jan 1, 2008 | 06:56 PM
8 Maniac's Avatar
Senior Member
I've called him and he didnt answer. Rather sure I found my answer on the power (seem to have missed details on his thread). Going to look to see if I can find some pictures of the throttle tap though.
Old Jan 1, 2008 | 10:37 PM
BDC's Avatar
BDC
BDC Motorsports
He's out in AZ and may not respond to a call. I haven't tried myself so who knows. But he's worth talking to if you're apprehensive about something that you may not be familiar with. From what I understand, he's quite good with the nitrous stuff and is pretty much considered the go-to guy in the 8 community here for it.
B
Old Jan 2, 2008 | 12:39 AM
Keef's Avatar
the shit starter
I use the cig. fuse, which I'm pretty sure is 10 amps for the power to my unit, and heater. Including being the REM wire for the amplifier. The place a sent the 12v wire through was the space below the master brake cylinder.
The color of the throttle body wire is in a picture somewhere on this forum
mr. GrandGame
Sep 9, 2025 10:41 PM
Pelleilee
Sep 29, 2019 10:07 AM
RA32425
Series I Engine Tuning Forum
10
Sep 8, 2015 08:53 AM
dancingdan42
Aug 19, 2015 09:29 AM
MolecularConcept
Aug 5, 2015 04:43 PM
