aftermarket rims with stock tires???
Old Jan 1, 2008 | 04:24 PM
J1MO7's Avatar
what are the dimensions of the rims i would get so that they will fit with my stock tires?
Old Jan 1, 2008 | 04:41 PM
DarkBrew's Avatar
Extraordinary Engineering
Well it depends...
You're not giving us much to go on... What model do you drive?
Old Jan 1, 2008 | 04:45 PM
J1MO7's Avatar
2005 rx8 sport 6 speed
Old Jan 1, 2008 | 04:58 PM
DarkBrew's Avatar
OEM wheels are 18" x 8" with a +50mm offset and a 5 x 114.3mm bolt pattern
Hub center Bore should be = 67.1mm
7.5 to 8.5" width will work with OEM tires
40mm to 50 mm offset will work.
Bolt pattern must match
Bore can be larger if you get hub centric rings
BTW, you need to use search!
Old Jan 1, 2008 | 05:02 PM
J1MO7's Avatar
so these wouldnt fit right? b/c of the offset????
http://newyork.craigslist.org/brk/pts/520246735.html
Old Jan 1, 2008 | 05:07 PM
DarkBrew's Avatar
Offset, bolt pattern and tire size are wrong.
Search on Ebay if you want something cheap that will fit.
Also see this thread.
https://www.rx8club.com/series-i-wheels-tires-brakes-suspension-55/good-places-buy-rims-134212/
Old Jan 1, 2008 | 05:15 PM
J1MO7's Avatar
im trying to find a deal for under 500
Old Jan 1, 2008 | 05:17 PM
DarkBrew's Avatar
With tires??
Check the for sale section on this forum
Old Jan 1, 2008 | 06:01 PM
kevinD1226's Avatar
ur not gonna find many wheel/tire packages for $500 keep saving and buy a decent set.. but u can try 1010tires.com they have some cheap stuff there
Old Jan 1, 2008 | 06:02 PM
07BB08's Avatar
Originally Posted by DarkBrew
With tires??
i have a buddy that is rolling his stock potenza's on his wheels. 225-45-18 has a nice stretch on a 9 inch rim
Old Jan 1, 2008 | 06:14 PM
DarkBrew's Avatar
Wow! that is a stretch. I'll bet that his rim guards don't work anymore...
Really good steering response I'll bet.
Old Jan 1, 2008 | 06:27 PM
J1MO7's Avatar
NO im not looking for tires, i want to use my stock ones
Old Jan 1, 2008 | 08:38 PM
DarkBrew's Avatar
These?
http://cgi.ebay.ca/ws/eBayISAPI.dll?...ksid=p3907.m29
http://cgi.ebay.ca/MAZDA-RX8-04-07-W...QQcmdZViewItem
Old Jan 1, 2008 | 10:19 PM
Aipex8's Avatar
X e p i A
The wheels from craigslist will probably work. I'm not sure why darkbrew says they are the wrong bolt pattern, but the ad I looked at said 5x114. The ad doesn't say how wide the rims are. The 35 offset is a bit aggressive, but if they are only 7.5 or 8 wide then you shouldn't have a problem. If they are 8.5 you may have to roll the fenders, but I'm not sure... 8.5 might work fine too.
Old Jan 1, 2008 | 10:35 PM
DarkBrew's Avatar
Bolt pattern listed is 5 x 114 not 5 x 114.3 so you'd have to check. It's probably 114.3mm
The tires are 40 series instead of 45 so the speedo would be off by quite a lot.
Old Jan 2, 2008 | 12:47 AM
Aipex8's Avatar
X e p i A
He said he'd be putting his stock tires on, so the aspect ratio shouldn't be a problem. Doing a quick search of all available bolt patterns reveals: 5 x 100, 5 x 107.95, 5 x 114.3, 5 x 115, 5 x 120, 5 x 120.65, 5 x 130. I'd assume he meant 114.3, but I'd probably email him and verify that and get the width.
Old Jan 2, 2008 | 01:01 AM
DarkBrew's Avatar
Also ask about the bore size if you email this guy.
michaelsk8er
Nov 9, 2015 07:06 AM
bulletproof21
Oct 20, 2015 08:53 PM
jdzoom8
Aug 19, 2015 03:32 PM
megaman
Aug 14, 2015 08:41 AM
MolecularConcept
Jul 26, 2015 09:09 PM
