Diff going out?!
Old Dec 26, 2007 | 01:27 PM
Shinka-05's Avatar
streetfighter
Diff going out?!
Okay, so I have about 30k on my car, and I drive it hard. I just wondering if anyone has had problems or knoticed thier diff going out at all. What I notice is when I have my tcs and crap turned off my diff does not lock, my right wheel will spin. so basically no possy traction... I have takin it to the dealer they, of coarse, do not think there is a problem.
Before people start raggin on me about search or stickies, I did search, but hard to find anything on the spacific simptoms.
My drivetrain is completely stock, and I have extended warrenty, and I am the first owner of the car. If someone has any suggestions, or links that would be great, also if anyone has similar symptoms or experiances with the dealer... of coarse the dealers try to deny everything so don't post about random problems. Thanks!
Old Dec 26, 2007 | 03:00 PM
nonconfrontational's Avatar
alter ego:confrontational
My diff clunks when I put it in reverse if I haven't driven it in a day or two, and occasionally when I shift from reverse to first.
Is this not the same thing? I don't have a solution, but I thought you might be interested to hear if someone else has diff-going-out symptoms.
Old Dec 26, 2007 | 03:10 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
You sure about this one being the diff? This seems like it might be the ole ABS brake check. Try to notice if it happens just as the car starts to move.
Old Dec 26, 2007 | 03:13 PM
staticlag's Avatar
The Professor
Do you have different tires on your rear? Any flats?
Old Dec 26, 2007 | 03:35 PM
Shinka-05's Avatar
streetfighter
All the same tires, never had a flat, and just put on new Falken 912's, bout a week ago... I had the 615's before and noticed about the diff before I put the new ones on.
Old Dec 28, 2007 | 10:56 PM
lilring's Avatar
Finally a MT
yeah i have an 04 AT and when i stop and a red light every once in a while the rear diff pops, and i also drive my car some what hard, but i have 38,000 miles on it and i already changed the rear diff fluid.
Old Jan 8, 2008 | 03:45 PM
Shinka-05's Avatar
streetfighter
Damn! I must be the only one with this problem... HA! looks like I will have to save up for a MS diff
Old Jan 8, 2008 | 04:05 PM
nmarz77's Avatar
Did you have too much fun in the snow/wet one day?
Old Jan 11, 2008 | 12:38 PM
06carbon8's Avatar
i have the same issue. pulling off from a stop, or taking a turn from a stop sign, the inside wheel will spin. i know it's a worn out diff, i have approx 30xxx on the car, i beat on the diff pretty hard. i'm either going with a carbonetic or kaaz lsd.
Old Jan 11, 2008 | 12:44 PM
Astral's Avatar
Purveyor of fine bass
The diff is only a 2x multiplier. I was able to spin the inside wheel from day 1, esp. if it's wet/slick or cold tires.
06carbon8, is this a change you noticed from when the car was new or at 15K?
Old Jan 13, 2008 | 04:13 AM
so the unweighted wheel spins.. and you think you have a problem with the diff?
Old Jan 13, 2008 | 04:14 AM
ok,
what is a 2x multiplier???? and see above..
wow.
Old Jan 13, 2008 | 07:46 AM
Shinka-05's Avatar
streetfighter
is the LSD that weak in the stock rx8 to constantly and easily have the unweighted wheel spinning?
Mazda NA should sell the MS diffs over here and warranty them. I heard dealerships won't even install them for you, and of coarse no ordering the part through them.
Old Jan 13, 2008 | 12:09 PM
Astral's Avatar
Originally Posted by swoope
ok,
wow.
What I meant to say is that the RX-8 torque bias ratio is 2.0. So the wheel w/ traction gets twice as much torque as the wheel with less traction. Consequently, if takes only a little torque to spin your wheel with less traction, your wheel w/ more traction is only getting 2x of that torque.
200.mph
Dec 10, 2018 03:49 PM
OfficerFarva
Dec 5, 2015 10:53 AM
nowakm99
Oct 9, 2015 07:10 AM
reni04
Aug 21, 2015 01:52 PM
