Putting new plugs in
Old Dec 26, 2007 | 09:44 AM
Vasichko's Avatar
I got some new OEMs from sparkplugs.com.
Just wondering if these things are pre gapped or not?
Old Dec 26, 2007 | 09:47 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
I believe they are already gapped and there is no real need to re-gap......................and see this thread.
https://www.rx8club.com/showthread.p...18778#poststop
Old Dec 26, 2007 | 10:57 AM
DarkBrew's Avatar
Extraordinary Engineering
My plugs arrived with gaps set and guards over the threads to protect the gap setting
Old Dec 26, 2007 | 11:18 AM
dtahbk's Avatar
If they are the oem type(NGK), the gap is already set and doesn't need to be adjusted.
Old Dec 26, 2007 | 11:50 AM
Nubo's Avatar
Lubricious
There's no guarantee. Measure it!
Old Dec 26, 2007 | 12:25 PM
SGTSAT's Avatar
Better safe that sorry,measure it!
Old Dec 26, 2007 | 01:30 PM
Mazurfer's Avatar
Yeah.......I do actually check mine, but really haven't found any over the years that I really had to mess with them.
Old Dec 26, 2007 | 07:04 PM
I never check mine, but I only change my plugs once. so ahh what do I know
Old Dec 26, 2007 | 07:10 PM
Charles R. Hill's Avatar
Owner of BHR
The way to check them is with a wire gapper as opposed to feeler gauges. I always check mine and have found them routinely out-of-spec.
Old Dec 26, 2007 | 08:11 PM
Old Rotor's Avatar
Vasichko
05' Grand Touring, 6MT, Velocity Red
How many miles do you have on them. I change mine at 33K, witch is before they are called for. They looked great and the gap was still right on. Is it idling smooth? Have you ever flooded it? They are pre-gaped at .048, but always check them with wire feeler Gage. Its worth checking with a two dollar tool before you put them in.
Old Dec 26, 2007 | 08:34 PM
Owner of BHR
Are you talkin' ta me? Are you talkin' ta ME? (DeNiro in Taxi Driver)
Old Dec 28, 2007 | 04:59 PM
Astral's Avatar
Purveyor of fine bass
aren't some of the NGK replacements also not even adjustable? (fixed?)
Old Dec 28, 2007 | 05:22 PM
staticlag's Avatar
The Professor
Yeah the lobe style ones like on the rx7
Old Jan 4, 2008 | 11:12 AM
Vasichko's Avatar
Ive got 28k miles on mine. I have had a rough idle for the past 2 weeks or so, sometimes it seems fine other times it seems rough.
I figure Ill just rule everything out and do plugs, coils, and I have some 10mm Magnacore wires Im gonna throw on there.
Originally Posted by Old Rotor
Vasichko
Old Jan 5, 2008 | 05:13 PM
Old Rotor's Avatar
Ok let us know what helps.
Old Jan 5, 2008 | 06:25 PM
Astral's Avatar
I put in new plugs yesterday. The biggest wire gapper I could find was .45". All of them were over .45". I had the NGK plugs from a Mazda dealer. All had the adjustable electrode.
My old plugs, trailing had 25K on them, leading (bottom) had 30K:
Old Jan 5, 2008 | 08:54 PM
DarkBrew's Avatar
Astral, those look good!
You weren't having any issues with your engine were you?
Mine looked just like yours and were replaced for preventive maintenance.
Old Jan 5, 2008 | 09:22 PM
Astral's Avatar
Those old plugs look good? Hmm, I guess so.
I was not having any issues. This is just regular maintenance. I didn't want to let my leading plugs go over 30K miles (schedule II maintenance is to replace plugs every 30K).
My coils look similar to your coils (actually a bit less burnt). I replaced them preventively anyways.
Things do seem to run smoother and pickup a touch better. That's probably due to completely clean plugs.
Old Jan 5, 2008 | 09:36 PM
DarkBrew's Avatar
You must drive your car like I drive mine
I just put in RB plug wires today and those seem to have made a difference to the feel of the engine; It seems smoother now... could be all in my head.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Ugafan97
SE For Sale/Wanted
Apr 28, 2016 03:35 PM
Prophet
Sep 4, 2015 11:03 AM
wanted797
Aug 26, 2015 11:24 PM
Redheddude222
Aug 24, 2015 09:14 AM
