ExoticSpeed coilover kit
Old Dec 22, 2007 | 02:20 AM
theakisrx8's Avatar
Hallo...
I'm new in the club but a 3years old owner of an RX8 standard power version (192ps 5MT) from Greece...
I have just bought from ebay the exoticspeed coilover kit for 1050 CA$ plus 100 CA$ shipping cost to Greece
And some information:
Features:
Steel McPherson bracket, damper Construction
Aluminum A-ARM strut upper mount
mono Tube internal construction
32 way adjustable dampers, compression and rebound combined
Ride Height adjustable via bracket/strut
Front & Rear Pillow ball upper mounts for increased steering feel and sharper cornering
Larger piston diameter for strut type front and rear damper in 50mm
Powder coated damper body with Zinc+ black chromium coated threaded section
Piston Rod made with polished steel and hardens material for the durability and reducing leaks in failed shocks
Piston Valve Consists of patented deflective disk valve stacks for precise performance.
Rod and Seals in high pressure inner rod guides seals ensure a perfect fit for consistent, fade-free damping and dependable performance
Warranty
2 year Manufacturers Defect Warranty
Contents of Damper Kit:
Adjustable Shock Absorber × 4 Bump Rubber × 4
Main Spring × 4
Hook Spanner × 2
Upper mount × 4
Dust Cover × 4
Seat Lock × 12
ESR1 32 levels damping force settings
0-8: Recommend for race track use
9-16: Recommend for Rally, mountain road use
17-32: Recommend for street and comfort use
Please give me your comments....
And please be patient with my bad English....
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Digitz0070
Sep 27, 2015 07:49 AM
Digitz0070
Sep 25, 2015 10:58 PM
