Replace the O2 Sensor ?
Old Dec 18, 2007 | 07:38 PM
I've been thinking, should I replace the front and rear O2 sensor ?
Cuz I've read some post that, these sensors can go bad but still not triggering a CEL until its completely dead, just like ignition coils.
and Im thinking I probably get can a few more mpg if I replace them, I know it will not offset the cost that easily (a new sensor, front, cost 240 something already), but ......... ahh I dont know.
Old Dec 18, 2007 | 07:44 PM
max5roadster's Avatar
INDY RX8 CLUB - Officer
240!? I will check around for ya, but are they not just 4 wire 02 sensors? If they are, you can get a replacement bosch unit for 60 bucks a pop.
Old Dec 18, 2007 | 08:11 PM
Reallllllyyyyy ... I forgot about bosch, hmm, I think the front is unique isnt it ?
let me find more info.
Old Dec 18, 2007 | 08:12 PM
These are not simple O2 sensors, not the front, anyway.
NY, I have an O2 sensor that has about 5 minutes of running time on it if you wanna save a few bux and do me a favor.
I pm u.
Old Dec 18, 2007 | 08:29 PM
Im done with the front sensor. trying to find some cheap rear sensor :O
Old Dec 18, 2007 | 08:40 PM
http://www.autozone.com/R,APP232934/...ductDetail.htm
I wonder will this work, it has 2 kinds of rear sensor, one (the above) saids Universal, and its 71 bux.
the other one O.E type, cost more than double, its even cheaper if I buy from Mazda.
so I wonder if the Universal one works with our car.
Old Dec 18, 2007 | 08:50 PM
Looking at it. Found some nice site
Hmm Now I wonder if the Universal will work .... cuz its like 1/2 cheaper than OE
Old Dec 18, 2007 | 09:23 PM
DarkBrew's Avatar
Extraordinary Engineering
I bought a Mazda OE rear O2 sensor on Ebay from Mazsport for around $80.
Old Dec 18, 2007 | 11:02 PM
Mind if I ask why did you replace yours in the first place ?
Old Dec 18, 2007 | 11:05 PM
DarkBrew's Avatar
CEL
https://www.rx8club.com/series-i-tech-garage-22/plugs-coils-131681/
Old Dec 19, 2007 | 12:40 AM
How many miles on your car when you had the CEL ?
Old Dec 19, 2007 | 05:58 AM
DarkBrew's Avatar
Just under 78000 km.
Old Aug 22, 2009 | 04:47 PM
CnnmnSchnpps's Avatar
No means yes
hey nycgps - did you ever find out if the universal sensor will work?
Old Aug 22, 2009 | 04:55 PM
Mawnee's Avatar
I divide by zero
wow, major thread bump
BTW, the rear O2 sensor is nothing mroe than a cat monitor. Its only job is to throw a CEL if your cat goes bad, so there would be no reason to replace it unless you have that CEL with a known good cat.
Old Aug 22, 2009 | 05:23 PM
Rote8's Avatar
Can you replace the front O2 sensor with a wideband sensor?
Will the stock ECU read a wideband?
Old Aug 22, 2009 | 05:52 PM
No means yes
I have a CEL for rear o2 heater circuit
Old Aug 22, 2009 | 06:05 PM
Mawnee's Avatar
I divide by zero
Unlike many other vehicles, the stock O2 on our RX8 IS a wideband.
Old Aug 22, 2009 | 06:41 PM
csl's Avatar
csl
Will an Ebay 4 wire O2 sensor works as ot suppose to be?
http://cgi.ebay.com/ebaymotors/OXYGE...Q5fAccessories
Old Aug 22, 2009 | 07:35 PM
O'Renesis's Avatar
The front and rear O2 sensors are not the same and are not interchangable.
If you are in the USA phone and ask if the heater element has a resistance of between 2.16 and 2.9ohms for the front O2 sensor and the rear O2 sensor between 14.1 and 18.9ohms. These parameters are monitored in the RX8 and if not within spec will throw a CEL.
Old Aug 22, 2009 | 11:52 PM
ms70616's Avatar
So did anyone find a cheaper alternative for the Front O2 Sensor?? mine needs replacing and dont really want to pay that much for one.
Old Aug 22, 2009 | 11:58 PM
Whoa ! My old thread ! LOL !
some of the aftermarket Universal sensor gave people CEL.
you dont even need to change them that often, just get stock ones.
and its easy to replace it yourself. some PB blaster or WD will help.
92trbolzr
May 18, 2025 09:04 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
fistofmeat
Oct 7, 2016 12:15 PM
drlubell
Sep 26, 2015 11:58 PM
Forevermore
Sep 20, 2015 01:04 PM
