No more flames?
Old Dec 15, 2007 | 06:28 PM
tajabaho1's Avatar
Destroying Threads
No more flames?
Hey guys, my car is a 2005, I have the mods listed below in my car
up until about a week ago, my car would be shooting flames (I have midpipe) if I WOT it and shift at about 8.5-9k RPM
however, in the past week, no matter how hard I drive her, my car doesn't shoot flames NA anymore, if I use nitrous, then she does but NA, she doesn't even have that "POP" sound anymore
A/F is about 14.4-15 NA WOT
is this normal? is it safe?
thanks
Old Dec 15, 2007 | 06:43 PM
mysql101's Avatar
in closed loop, 14 is standard. In open loop, you usually see stuff in the 10 and 11's. So WOT at 14 sounds lean.
Old Dec 15, 2007 | 06:44 PM
8rotor8's Avatar
Back in the day...
Reset your Ecu.
staticlag's Avatar
The Professor
Probably just the weather cooling down
Old Dec 15, 2007 | 07:37 PM
tajabaho1's Avatar
Destroying Threads
its about 15-17 degrees celcius over here
I already did, still doesn't shoot flames........
should I be worried?
Old Dec 15, 2007 | 07:42 PM
chetrickerman's Avatar
it shouldnt shoot flames when lean
Old Dec 15, 2007 | 07:44 PM
tajabaho1's Avatar
Destroying Threads
sorry, I got the AF numbers wrong
its about 13.2-13.6
is that still lean?
I will reset the ECU again tonight
Old Dec 15, 2007 | 07:45 PM
is that at WOT?
Old Dec 15, 2007 | 08:15 PM
tajabaho1's Avatar
Destroying Threads
yes, at WOT, you can see it in my dyno
Old Dec 15, 2007 | 08:16 PM
its still not rich, as long as its not something like 15 or 16 your good
Old Dec 15, 2007 | 08:21 PM
tajabaho1's Avatar
Destroying Threads
ok, I resetted my ecu again and gone on a 5 minute warming (6k-9k rpm) the entire time, it makes that bubbly sound, still no pop though
but, my car is fine other wise, nothing bad, dynoed pretty strong and everything, wierd I think I'll just add 1 size jet to my nitrous just to be on the safe side
Old Dec 15, 2007 | 08:24 PM
13's are fine for WOT. you would want cruise or idle to be stoich
Old Dec 16, 2007 | 04:45 PM
staticlag's Avatar
The Professor
flames/backfire is dependent on exhaust system temp(and AFR), try revving it in place at high rpms.
Old Dec 16, 2007 | 10:38 PM
tajabaho1's Avatar
Destroying Threads
^ I tried
I tried everything, it just doesn't shoot flames anymore, I don't really care about the shooting flames, I am just worried it might point to my system running too lean etc etc
Old Dec 16, 2007 | 10:40 PM
MazdaManiac's Avatar
Is that 13:1 with the nitrous spraying?
Old Dec 16, 2007 | 11:21 PM
tajabaho1's Avatar
Destroying Threads
no, thats NA
with nitrous its at 10-10.7 and it does shoot flames with nitrous
but without, nada T.T
iwontevercare
Jul 18, 2015 09:25 AM
Velocity-8
19
Feb 14, 2004 03:33 AM
SilverTrigger
18
Jan 28, 2004 08:35 PM
