lug nuts
Old Dec 13, 2007 | 11:01 PM
imput1234's Avatar
I ♥ Drifting!!!
lug nuts
dumb question.
What is the size of the OEM lugs?
Thanks.
Old Dec 13, 2007 | 11:42 PM
imput1234's Avatar
I ♥ Drifting!!!
Anyone? please lol
Old Dec 13, 2007 | 11:46 PM
M12x1.5
Old Dec 13, 2007 | 11:55 PM
imput1234's Avatar
I ♥ Drifting!!!
Originally Posted by dannobre
M12x1.5
Ok. Thanks
Old Dec 14, 2007 | 02:00 PM
Endless Rotaries's Avatar
So specs:
As mentioned:
12x1.5
Other things to consider based on the type of wheel you got.
Lugseat: Cone Seat/Acorn, Ball Seat, Shank
Lugnut Diameter: Tuner = SMALL DIAMETER/HAS KEY, Standard = 19mm or 21mm socket, NO KEY...
Rishie
Old Dec 14, 2007 | 03:06 PM
lesper4's Avatar
T-29 years and counting
boy, that just confused me.
Old Dec 14, 2007 | 04:00 PM
Most all Aftermarket wheels use a CONE Seat/Acorn Style Lugnut. This is the shape of the bottom of the lugnut that touches the wheel lugseat.
12x1.5 is the thread pitch
Some wheels have BIG HOLES, can use a standard lugnut
Other ones have puny holes that will require a tuner lugnut.
Hope that helps.
Old Dec 14, 2007 | 04:47 PM
I know of some girls that have big holes.
Does that count as being knowledgable about wheels?
Old Dec 14, 2007 | 05:52 PM
Those girls sounds more like a "ShANK" lugnut seat to me...
Old Dec 14, 2007 | 08:33 PM
TrochoidMagic's Avatar
is adjusting valve lash
^^lol!
so does the enkei rpf1's use the tapered seat/acorn lugs like stock? just wanna make sure i can keep my kyokuken lugs which is currently on my stocks.
Old Dec 14, 2007 | 09:02 PM
DarkBrew's Avatar
Extraordinary Engineering
I got some of these
http://store.summitracing.com/partde...5&autoview=sku
Old Dec 14, 2007 | 11:56 PM
Yes RPF1's should be able to take the stock ones. Cone seat for sure.
STock lugs take a 21mm socket, 19mm is better though so you don't mark up the inside of the lugseat walls with the 21mm socket.
Rishie
Old Dec 15, 2007 | 12:01 AM
mysql101's Avatar
get mcgards:
http://store.summitracing.com/egnsea...2&autoview=sku
They're a two piece lug nut. The part that touches the rim doesn't rotate and grind into the rim as you tighten. They work really well, and the tool to tighten/loosen is very thin at the edge, so it'll fit any rims you own. Did I mention they're light weight?
Old Dec 15, 2007 | 01:32 AM
imput1234's Avatar
I ♥ Drifting!!!
I was thinking of these, they have it in M12 x 1.5 so it should fit correct?
I'm going to use these with the factory wheel btw
It says ". DO NOT USE THESE TUNER LUGS FOR YOUR FACTORY WHEELS" Why?
http://www.evasivemotorsports.com/me...e=T1R_BMAX_LUG
Old Dec 15, 2007 | 09:36 AM
ChuLooz's Avatar
registered abuser
nice choice in lugs, i am thinking about getting some new rims, and did some research for a lightweight lug nut and those were the lightest i found, with in a decent price range. plus they are forged. as for the comment on not using them with your stockers, it most likely has to do with their seat, im not sure tho. i've contacted them before and they are very friendly and quick with there responses.
Old Dec 15, 2007 | 07:13 PM
imput1234's Avatar
I ♥ Drifting!!!
I think it's because of the chamfer angle, but have no clue why it would matter since the curved part is on the outside
200.mph
Dec 10, 2018 03:49 PM
hppy4u
Gulf For Sale/Wanted
9
Dec 3, 2015 09:11 PM
RXBae
Sep 14, 2015 03:54 AM
WingleBeast
Sep 9, 2015 10:10 AM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
