FEED Alternator
Old Dec 13, 2007 | 12:22 AM
xbeatxdownx's Avatar
FEED Alternator
So I was looking at the FEED website earlier and I noticed the have an alternator. Does anyone know how to get it and how much it would be or how different the power from it is compared to stock?
Old Dec 20, 2007 | 05:33 PM
csw1986's Avatar
RX-late
Hm.. interesting because my dealer said there isn't any aftermarket alternator for rx8 out there now.
Could you tell me that FEED website so I can also check that out?
Thanks,
Old Dec 20, 2007 | 06:43 PM
really, let me take a look
Old Dec 20, 2007 | 06:46 PM
ooo
*130A Big Capacity Alternator*
It saids 130a (amp I assume) power, Stable power, stronger ignition, more complete combustion, Best for Hi Wattage Audio equipped cars !
http://www.fujita-eng.com/rx8/img/pl_041.jpg *Picture*
http://www.fujita-eng.com/rx8/index.html *link*
Sounds pretty good, but its like 600 bux. thats really steep for an Alternator. but I got their Big Clutch Release with hose for 300 bux. This Alternator dont seem that bad.
Old Dec 20, 2007 | 06:53 PM
Damn it xbeatxdown !!!! Why you have to show us FEED has that thing out !
Cuz now Im thinking should I buy one .... grrRRRRRR
but hmm whats the stock output again? (again)
Old Dec 20, 2007 | 07:13 PM
tajabaho1's Avatar
Destroying Threads
definitly gonna buy this **** when I go to japan, muhaha, im gonna buy it all!! hahaha
Old Dec 20, 2007 | 08:45 PM
Juice's Avatar
I made some poos
Stock output I believe is 100 so its not that great. There are some threads in the audio forum about replacements that are like 200 amps for around $450. I'll see if I can find the threads and edit this.
EDIT: Found It!
https://www.rx8club.com/series-i-interior-audio-electronics-24/high-output-alternator-131393/
Old Dec 20, 2007 | 08:49 PM
yeah stock is 100. just got mine tested. yeah though anyone know where or who can get this. im willing to pay now if anyone can give me some advise where to get it.
Old Dec 20, 2007 | 08:54 PM
Juice's Avatar
I made some poos
Japan Parts, or Invision Performance could probably get the FEED alternator for you. They are vendors and their forums are found at the top of the main page.
Old Dec 20, 2007 | 11:40 PM
Is it worth it tho ?
600 bux is a bit expensive, I dont have any *super duper* speakers or subs in my car, I want to get something better because I think it should help the ignition system to work better, perhaps be able to charge the battery better.
if the Iraggi Alternator works just as fine, then why not ? 450 sounds better than 600 bux.
Old Dec 20, 2007 | 11:53 PM
Juice's Avatar
I made some poos
Personally, I don't think 30 amps and the name FEED is worth 600 dollars. Especially when you can get an extra 120amps for 450. It should help the charging system and help alleviate the loss of power (like when headlights dim or windows go down slower than normal) when alot of load is put on the system from extra audio or ignition upgrades.
Edit: I just read your post again and I haven't had any experience with the Iraggi alternators so I can't help you with that question. Also, even if all you wan't is a little more power, there isn't any reason to not get the highest powered alternator you can afford. It won't hurt the electrical system in the car and its always good to be able to have the extra power if needed for upgrades in the future.
Old Dec 21, 2007 | 08:35 AM
You forgot one thing, Its BLUE !!!!!!
Will it have problem if I go 9K Rpm ? Maybe I should ask the guy directly.
Old Dec 21, 2007 | 02:50 PM
Juice's Avatar
I made some poos
Yeah, it definitely looks great. I guess if you want something pretty and has some better performance then the FEED would be alright, but I'm sure you can paint or powdercoat any alternator to look as good or better for less money than the 150 dollar markup for the name FEED.
As far as the 9k rpms I am sure it will be fine, but I've emailed him to ask. I'll post up what he says when he replies.
Edit: I kind of sound like an ******* about the FEED alternator. I'm sure it works great, but I am pretty cheap and it just doesn't do it for me for what else I could get.
Old Dec 21, 2007 | 03:29 PM
Is that because you are drunk and disorderly?
ah.............
Old Dec 21, 2007 | 03:34 PM
Juice's Avatar
I made some poos
No not yet, but I'm getting there!! Got a 64oz jug of Harpoon IPA for free so thats gonna be gone in a couple of hours
Old Dec 23, 2007 | 10:24 PM
chickenwafer's Avatar
Nope
Hmm I would be interested in a higher amp alternator, nothing crazy tho, just a 180a.
The FEED is nice but not powerful enough and too pricey- maybe if it was 180a I would consider.
My headlights dim when I run my CarPC and have my radiator fans running at the same time- they dim quite a bit. Plus, the alternator gets extremely hot, hotter than the rest of the engine, which leads me to believe the alternator is working overtime.
Old Dec 23, 2007 | 10:31 PM
you actually dare to touch it when its running? O_O
Hmm, mine dim even when I roll my power window down ~~~~~~
Higher Amp Alternator, Here I come ! (but see if it works under 9K rpm)
Old Dec 23, 2007 | 10:43 PM
lurch519's Avatar
www.evoperform.com
ohio generator should be able to provide a TRUE h/o alternator for the 8, with direct bolt on plug in fitment. by true h/o, i mean 150 to 200 amp, most likely about 180 range, for about 600
Old Dec 23, 2007 | 10:52 PM
Any links to share ?
Old Dec 23, 2007 | 10:59 PM
lurch519's Avatar
www.evoperform.com
http://www.ohiogen.com/
Old Dec 25, 2007 | 03:36 PM
Nope
No, I don't touch it while it's hot, that would be stupid. Use an infrared temperature gun to measure the surface temps. The alternator gets over 280-degrees F while everything else is in the 240-260 range. The second hottest object under the hood is the oil filter
Old Dec 25, 2007 | 05:35 PM
olddragger's Avatar
alternator needs a fan on the pully
oscd
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
OnebaddRx8
Aug 25, 2019 11:34 PM
mdl0209
May 23, 2019 05:46 PM
