Chugging at 80mph at 4-5K RPMS
Old Dec 10, 2007 | 09:00 PM
monte66's Avatar
My RX8 is a 2004. I'm having an issue with the car chugging (jerking/missing) at 80 mph to 90 mph at constant pressure on the gas pedal. If I give it gas the chugging stops. I do not experience this at any other speeds. Another interesting thing, it the car is in cruise at 82 it is fine until I head up a slight hill then it does it again. I have pulled the plugs and they are fine. I also have changed all four ignition packs. Suggestions? My thought process is to change the pug wires next! Also if i go the plugs are the Nology plug wires worth the money? Thanks
Monroe
Old Dec 10, 2007 | 09:55 PM
invasion08's Avatar
No the nology plug wires are not worth it go to www.mazsport.net and get their plug wires. Trust me
Old Dec 11, 2007 | 07:02 PM
Huhwha's Avatar
Check the rear O2 sensor.
Old Dec 11, 2007 | 08:11 PM
monte66's Avatar
Testing rear O2
Thanks for the plug wire info. Are the plug wires from factory or performance?
The O2, can I test it without replacing it? Another question, the exhaust is 3 1/4 inch Greddy with not cat. Will that affect the back O2? Thanks for the help
Monroe
Old Dec 12, 2007 | 09:45 AM
agoodcave's Avatar
I had the same problem once with a Ford Aerostar. Tried tune-ups, plugs, etc. It always came back about a week later. Ended up it was the Throttle Position Sensor.
Mike
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
D13
Oct 1, 2015 07:55 AM
tommy26Germany
Sep 29, 2015 10:33 AM
