Gas in OIl nightmare HELP!!!
Old Dec 7, 2007 | 12:36 PM
nelsonrx8's Avatar
i have a friend that is useing a zex nitrous kit and he just checked his oil and it was full of something that smelled like fuel...i think seals are gone.he has a warrenty so i told him to pull out the kit and bring it back what do you guys think
Old Dec 7, 2007 | 12:48 PM
architect's Avatar
Tell your "friend" he's a ****** idiot. You dumbasses blow your engine using nitrous then you expect Mazda to pick up the tab?... which in turn 1) raises the price of extended warranties 2) Forces manufacturers to shorten warranty periods 3) lowers the reliability rate and 4) lowers resale value.
You broke it, you fix it.
Old Dec 7, 2007 | 12:51 PM
nelsonrx8's Avatar
thats was help full thank you
Old Dec 7, 2007 | 12:58 PM
Red Devil's Avatar
He's probably experiencing fuel dilution, which is normal in rotary engines - especially ones running more hp than NA. Tell him to change his oil more often.
Old Dec 7, 2007 | 01:08 PM
wcs's Avatar
wcs
no agenda
You're an f'n dick, you're right but you're a dick.
Takes one to know one so there!
I've got the Zex system installed so I'm interested in how this turns out. That being said I may not have a high post count but I lurk a lot. I don't recall coming across any threads that mention fuel in the oil
Have you tried changing the oil?
My limited experience with 2 stroke motors reminds me that often the crank case would fill with fuel if you flooded the motor (again and again and again). Have you experience starting issues?
Compression test?
Is it the Zex wet system perhaps something is wrong with the fuel solenoid not shutting off? Ray where are you???
Just some ideas....
Old Dec 7, 2007 | 03:25 PM
nelsonrx8's Avatar
"HE" JUST CHANGED IT @) MINUTES AGO damn caps so we will see how it turns out "he" said its running better ill get back sh tomarrow
motor flush aswell
Old Dec 7, 2007 | 03:36 PM
CnnmnSchnpps's Avatar
No means yes
Hey, Mazda doesn't cover warranty repairs no matter what you do, so screw them...
Old Dec 8, 2007 | 07:14 PM
nelsonrx8's Avatar
thanks you are right running great now and stronger then ever
Old Dec 8, 2007 | 07:29 PM
motor flush!
You need to change the oil again.
We have around 6 quarts. You can only get about 5 changed.
The rest is in the lines and oil coolers.
Change it again. I wonder if that flush is ok for the Apex seals.
Old Dec 8, 2007 | 09:51 PM
RotaryResurrection's Avatar
kevin@rotaryresurrection
Some members of this forum believe that a renesis cannot fuel dilute the oil supply. I am not one of them.
Change the oil with cheap walmart oil, run it half an hour, then drain and change again. Then monitor the dipstick over the next little while (1000-1500 miles) for both level and smell.
Old Dec 10, 2007 | 10:11 AM
mac11's Avatar
Rotary , eh?
Have to agree here. After doing water treatments I always find water in the oil in the form of milky froth as is known to accumulate during the winter months and general condensation. This is always done immediately before an oil change, and from now on probably a double changes as outlined by RR above.
Old Dec 10, 2007 | 04:48 PM
2k4_8's Avatar
I had serious fuel dilution problems bc I live less than 2 miles from work, now I just warm the car up as much as possible first, not as *much* of a problem now, but I still get a little bit. It smelled very rich w/ raw fuel when I changed it last time. I changed my habits a little and hope the next oil change goes better.
RevMeHarder
Jun 1, 2026 02:30 PM
GARCIAC951
Sep 10, 2015 07:17 PM
titaneum_grey
Sep 6, 2015 10:21 PM
wayloco
Sep 1, 2015 09:03 PM
