04 Rx8 with headlight problems
Old Dec 3, 2007 | 09:14 PM
mazdasp's Avatar
can someone help.....the lights always come on at first.... but the rh front starts to flicker after its been on a while...THE LARGE MAIN BULB..then it goes out!!! It will always come on again when cold...I will sometimes work for awile (a few days or so) with no problems.. it has hid,s Lights 17 K miles 2004 rx8 It sounds like Ballast problem but since a new one is over 900.00 and bulb 200.00 or so from the dealer...At those prices Im not sure of anything!!!! My own car is a mazda speed mx5.. and this car is a Lady frien..d of mines....I would like to do my homework....also what needs to be removed to get at the bulb and or the ballast!! WALT
Old Dec 3, 2007 | 09:25 PM
DarkBrew's Avatar
Extraordinary Engineering
Not sure but here's a link to the shop manual
http://smrmicro.com/rx8servicemanual/
Check the connectors. They cause trouble here and there.
You could switch the bulb to the LH side to see if it works and try to narrow things down.
Check with some of the parts vendors here if you need parts.
Place an ad in the wanted section as an alternative.
Also, very important:
If you replace the bulb read the warnings and follow the instructions.
Old Dec 3, 2007 | 09:27 PM
G3tR3DDY2GR3DDY's Avatar
sounds like a ballast problem to me. if it were a bulb it would just go out and your done. but bulbs dont often go out at that age especially not HID's. I wish i could help you more but i think your lady friend should have it checked out at a Mazda dealer to find the problem. If something is broken from wear and tear try to find a used headlight on ebay. Good luck!
Old Dec 7, 2007 | 12:57 PM
Gauge's Avatar
Not Jeff Gordon
Same problem here, with aftermarket..
Old Dec 8, 2007 | 05:16 PM
ninco's Avatar
04 RX-8 HID Problem
Interesting...
I just started having this problem with my aftermarket HIDs. I purchased them back in July 07 and never had any issue until now.
My aftermarket HIDs are rated at 6K Kelvin.
They would turn on with no problem, but after driving home and stoppping for gas, then to turn the lights back on, bulb would not turn on.
After 2 instances of this, I put the OEM HID bulbs back in and have NOT had anymore problems.
I plan to put my aftermarket bulbs back in and switch sides to see if the problem follows. I truly hope so.
I called the local dealership for pricing on a ballast and these people are straight tripping ($720 each without HID bulb).
I have been reading on the net and I find that people really push using Phillips bulb product, rather than an off brand HID bulb company.
My aftermarket bulbs are made by Sylvania. I found some Phillips bulbs, but these things are waaay more expensive.
Old Dec 8, 2007 | 09:48 PM
Gauge's Avatar
Not Jeff Gordon
Ive had mine about 8 month's and the #!@$%^@ is almost dead or out of gas, same thang...Called the people, warranty just expired... $109 for a new bulb...bs
Old Dec 9, 2007 | 03:47 AM
paulmasoner's Avatar
Asshole for hire
the phillips bulbs are more expensive for a reason. Phillips is the only company that has a consistently good track record with HIDs. you may find other bulbs that will be great, but its a gamble.
Gauge: pics plz
Old Dec 28, 2007 | 05:32 PM
ninco's Avatar
Philips HID bulbs
I purchased the 6K Philips bulbs and have been running with these for about 2 weeks. When I put my original bulbs back in, I had no problems, but I was not satisfied with the color of the original bulbs.
I have the 6K color range that I was used too. I purchased the bulbs from Xenondepot.com. Cheaper than the dealership, but more expensive than the other place I purchased from.
Philips ($99 each bulb) versus PlasmaGarage.com ($75 each bulb).
ladnarf1
Apr 29, 2021 11:53 PM
Skyl3r
Dec 2, 2019 04:51 PM
TheAlbinoRhino
Aug 4, 2015 09:48 PM
Belalnabi
Jul 17, 2015 07:48 PM
