ABS, DSC, and E brake Light is on need help
Old Nov 30, 2007 | 12:43 PM
bhavax's Avatar
My ABS and my DSC just went on when i start driving and my brake light turn on as if the E brake was still up what should i do?? i don't want to bring it to the dealers because if a simple fix why pay a lot of cash if it's just a simple problem that could be fix with C4 explosion under my hood JK lol you what i mean. all the wheels are the same size too everything is still stock so i dunno. well PLZ PLZ if anyone could help and live in the Socal Area Lunch is on my, for anyone else some where else you got E prob from me for ever lol lol
Old Nov 30, 2007 | 02:10 PM
RenKat's Avatar
PM me I might be able to help.
Old Nov 30, 2007 | 03:05 PM
puffxy's Avatar
I had the same problem. I was going to bring my car into the dealer because it was 20 days old at the time, so I placed my stock wheels back on to make sure they had nothing to complain about. Lights went away with the stock wheels.. so I put the volks back on and checked the tire pressure.. they weren't off by much.. probably 4psi variation at most, but evened them back and and the lights haven't been back.
First thing I'd check would be tire pressure. Good luck!
Old Nov 30, 2007 | 03:13 PM
He||hammer's Avatar
Destroyer of Dreams
Check Alt and Battery I have every light on my car go on while I was trying from those 2 things, hope the car is ok
Old Nov 30, 2007 | 10:13 PM
bhavax's Avatar
the battery ok because that is new my wheel is stock and PSI is at 35 i just got an aliment done to it damit i i dunno maybe could be the fluid NO i change that already . oh!! yeah how when i put the OBD 2 Censer reader on it, it doesn't read, it just said ERR Link !?!?!?! dam That was a waste anyone know whythe OBD 2 reader is not reading
Old Nov 30, 2007 | 10:17 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
When they did the alignment, they may have knocked one of the wheel sensors loose or damage the connector. Go look on all four corners and see which on the messed up! With you putting the e-brake in there......I would say check the rears first!
Old Dec 2, 2007 | 03:11 PM
DOMINION's Avatar
I don't buy Kool-Aid
I have the same thing right now. My friend just changed my stock springs to Tanabe springs right now and now the ABS and the E brake light is on.
You think its the wheel sencors?
Old Dec 2, 2007 | 03:20 PM
RNE515's Avatar
what a wankel!
Wow, that is interesting timing...I had the same thing happen this morning. I turned the car off and on and hey presto the lights disappeared?
I assume I haven't just hidden the problem?
Old Dec 4, 2007 | 12:44 AM
DOMINION's Avatar
I dont know. I let my car sit over night and on the way coming to work they where still on?
Old Dec 4, 2007 | 03:09 AM
bhavax's Avatar
try bleeding your break it might work i just bleed my all the light when off it went back to normal
Old Dec 4, 2007 | 07:54 PM
DOMINION's Avatar
Dam. So much for sleeping in on the weekend lol but thanks! I'll give it a shot and let you guys know how it turns out.
Old Dec 6, 2007 | 11:06 PM
Be Careful. My alternator was faulty and overcharged the system which resulted in those lights plus more. The damage was to the ABS brain to the tune of $2,300.00. Get it checked ASAP. I waited which resulte din more damage. Not saying my problem was the same as yours because my power steering light was on but had I had the alternator checked earlier I could have avoided the damage.
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
stickmantijuana
Sep 4, 2015 10:31 PM
