3 piece pulley kit
Old Nov 27, 2007 | 07:42 PM
kevinD1226's Avatar
3 piece pulley kit
does anyone make a 3 piece pulley kit that only underdrives the crank and nothing else? i know AP makes only 1 pulley but i wanna changed all 3
Old Nov 27, 2007 | 07:48 PM
chetrickerman's Avatar
unorthodox?
Old Nov 27, 2007 | 08:28 PM
WoodsOfGreenRx8's Avatar
So MANY threads on this..
Old Nov 27, 2007 | 09:36 PM
kevinD1226's Avatar
ya but none of them seem to answer wat im asking trust me ive searched either the search feature on this forum sucks or i just dont get it
Old Nov 27, 2007 | 09:38 PM
kevinD1226's Avatar
i believe unorthodox underives them all i believe they say something on teir website about havin a set that only underdrives the crank but theres so seperate order # or anything and i tried emailing them no answer its been about a month
Old Nov 27, 2007 | 10:28 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Unorthox sells two types, one that underdrives by 20%(the Ultra SS) and one that doesn't and gets the gains from being much lighter than stock(Ultra SSc). I actually ended up going with 20% underdriven and have seen no ill effects in Florida(it's hot here).
www.unorthodoxracing.com
Here is a statement(s) right off the website:
"Our pulley sets provide most of the power gains through weight loss (80-85%). The remaining part of the gains from these pulleys comes from underdriving of all the accessories (15-20%)."
"However, we do not push underdriving for two main reasons. First, it is important to keep charging systems, air conditioning, power steering, and water pumps moving fast enough for every day driving. Second, not much horsepower is gained from extreme underdriving."
"In most applications all of our underdriving is done with the crank pulley, not the accessory pulleys. This is done so maximum weight loss can be achieved at the crank where most of the horsepower gains are found."
Old Nov 27, 2007 | 11:28 PM
staticlag's Avatar
The Professor
Well, when the crank is under driven, so is everything else
Old Nov 28, 2007 | 12:36 AM
the Speedsource racing set (sold only through Mazda Motorsports) only changes the crank and alternator pulley
(and eliminates the AC crank pulley which you can do anyways with any pulley kit, the exception is the OE AC crank pully won't mount to the Speedsource crank pulley)
the point is more isn't necessarily better, don't look now but your n00b skirt is showing
Old Nov 28, 2007 | 03:28 PM
yes, but typically the ideal combination requires underdriving the various items different amounts, hence the multiple pulley change
if you make the crank pulley smaller to underdrive the OE water pump pulley to the optimum then a change in the alternator pulley is required to balance it out relative to the first change. This makes changing all three irrelevant from a performance perspective.
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Digitz0070
Sep 27, 2015 07:49 AM
Digitz0070
Sep 25, 2015 10:58 PM
