Surging idle
Old Nov 26, 2007 | 08:23 PM
fuel90's Avatar
Surging idle
This car is driving me nuts. For several months my engine has been surging by about 700 rpm from idle. When I first start the car with a cold engine, it idles very high (about 3500) and then as it drops it begins to bounce, as though it's trying to recover from dying. If I press in the clutch, it goes away. As the drive-train warms up it eventually stops. The check engine light is on alot, too. I've taken it to the dealer four times now and left it overnight, but they can't recreate it (which I find hard to believe) and the check engine light always turns off on my way to the shop. I want to sell this car but can't because it's apparently unfixable. Any similar experiences? Thanks.
Old Nov 26, 2007 | 08:27 PM
tajabaho1's Avatar
Destroying Threads
see whether the coils are firing correctly, especially since I see it happens when its cold........tranny issues would be second guess.........mine does it too, but not while standing still........its been covered in another thread......
Old Nov 26, 2007 | 08:32 PM
Silver8-04's Avatar
you man.. check out my thread.. i have the same problem.. in my thread it says the codes from my check engine light. Its a problem that is hard to explain to anyone. Let me know if you find anything out from your dealer, my dealership has been hesitant to help b.c i have upgrades.
Old Nov 26, 2007 | 08:34 PM
Silver8-04's Avatar
https://www.rx8club.com/series-i-trouble-shooting-95/serious-issues-need-help-asap-131698/
Old Nov 26, 2007 | 09:37 PM
Old Rotor's Avatar
I believe thats the "Clutch Switch"....check that out....
Old Nov 26, 2007 | 09:55 PM
Silver8-04's Avatar
yea man.. but.. dont you think the CEL would throw a code for that if that is what it is?
Old Nov 26, 2007 | 10:24 PM
it is the neutral pos switch, it will throw a code, but it takes a long while...
Old Nov 26, 2007 | 11:23 PM
fuel90's Avatar
nuetral pos switch... actually, the dealer found that as a stored code even without the light. He checked the switch and said it was fine and then reflashed the computer with several upgrades. It runs smoother now but still has the same basic problem.... thanks for the heads up.
Old Nov 26, 2007 | 11:34 PM
fuel90's Avatar
I also suspect the O2 sensor/convertor or another environmental issue that could affect the fuel mixture but the dealer won't check anything out without being able to recreate the issue. It seems that it goes away only after the whole drive-train has heated up (ie after the engine temp has been warm for a while) which makes me suspect something downstream of the engine. Thanks for all the suggestions.
Old Nov 27, 2007 | 08:56 PM
the switch is bad..
theblinkof
Oct 4, 2023 05:24 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
Danield97
Sep 30, 2015 05:59 PM
Quiggs321
Sep 30, 2015 05:34 PM
