Replacing REAR brake pads on RX8
Old Nov 25, 2007 | 07:48 AM
cartnerka's Avatar
I am a first timer for do it yourself brake pad replacement. Had no problem with the fronts but rears are giving me fits. i understand the rear piston rotates into the caliper instead of just pushing in like the fronts. Any tips on how to get the rears piston in far enough so I have clearance to get new pads on rotor?
Old Nov 25, 2007 | 08:45 AM
expo1's Avatar
He's as bad as Can
These two threads should be of help
https://www.rx8club.com/series-i-tech-garage-22/tool-push-rear-brake-caliper-cylinders-72878/
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-brake-pad-replacement-68073/
Not only do you have to screw in the rear piston, there is a small tab on the rear of the pad that needs to slide into the grove of the rear piston. Try making small turns to the piston the align the grove wit the tab.
20b-3rotor
Sep 2, 2015 11:09 AM
thewatcher101
Jul 27, 2015 09:44 PM
Houston Sooner
Jul 21, 2015 07:45 PM
AussieGray
Jul 16, 2015 03:58 AM
