blown engine?
Old Nov 22, 2007 | 02:47 PM
VRRX8's Avatar
blown engine?
Ok, the car runs like ****, and sounds like a v8 on steroids, i think that i blew the apex seals on one of the rotors, someone also told me that the timing might be bad cause i have no cat, and that the na rotaries need back pressure, so that may have caused the timing to get messed up... can anyone help
Old Nov 22, 2007 | 03:42 PM
invasion08's Avatar
Go to the dealer and get a compression test done
Old Nov 22, 2007 | 04:37 PM
2jz- rx8's Avatar
if the car sounds like **** and it turn of if your not giving it gas and your smoking then yes you have a bad apex seal.
Old Nov 23, 2007 | 12:30 AM
if it smokes ALOT, you might have a blown seal.
but if it just *really loud* and *lack of power*. It might be dead engine, but it also could be foul Plugs, bad coils, bad spark wires, etc.
So check first. Dont conclude it so fast.
Oh, Cat-Free will NOT mess your timing up. All you will get is a CEL that means *cat effciency below therashold* or something. and thats it.
Old Nov 23, 2007 | 12:33 AM
Old Rotor's Avatar
What is the history on your car?
Old Nov 23, 2007 | 10:58 AM
Brian_TII's Avatar
A blown apex seal doesn't mean it will smoke... just run like he described... Typically it will want to stall if you let off the throttle.
Old Nov 24, 2007 | 12:51 PM
VRRX8's Avatar
it dies every once in a while, it does not smoke, but it does backfire like crazy, mods to the car are only, intake, full exhaust with no cat, and greddy emanage with the na map
Old Nov 28, 2007 | 02:34 PM
VRRX8's Avatar
anyone else have an idea?
Old Nov 28, 2007 | 03:10 PM
if under warranty, change it back to stock take it back and have a dealer take a look. but I doubt they will be able to fix anything, dealerships are useless.
Old Jan 25, 2008 | 06:18 PM
SRrx-8JC's Avatar
Felix "The Man" Wankel
I think I may have the same problem, VRRX8 have you pulled any codes??
Old Jan 26, 2008 | 12:57 AM
yep,
a couple, but you provide almost no info...
first take of the emanage..
ouimetnick
25
Sep 14, 2023 01:44 PM
vapor2
Nov 3, 2020 03:38 PM
delicious_dallan
Jan 17, 2020 09:17 AM
FITF
Aug 17, 2015 04:53 PM
westgman
Good Guy/Bad Guy
Jul 15, 2015 11:18 PM
