Recommended Mazsport NGK spark plugs
Old Nov 22, 2007 | 01:53 AM
rx808boi's Avatar
Who on here runs the NGK plugs recommended by mazsport?
-NGK BUR78EQP(Leading)
-NGK BUR9EQP8(Trailing)
I had some problem with the NGK 5255 plugs not igniting all the fuel and letting bypass the rotors and straight out the exhaust port (being that my car sounds like its drowning @ 7k and lose power ) so I want to switch back to OEM RE9B and RE7A but they are too damn expensive($133.75 both leading and trailing ) and the NGK plugs from mazsport fits my budget very well($53.96 both leading and trailing. ) But I notice the mazsport plugs are at a cold stage and so were the 5255plugs so will I still have the same problem? should I just stick with the OEM NGK's? or should I just go with the mazsport plugs? thanks for the help in advance
Old Nov 22, 2007 | 10:02 AM
Icemark's Avatar
You can pick up the OEM spark plugs for $20 each at sparkplugs.com
The BUR7EQP8 and BUR9EQP8 are just re-gapped RX-7 13B platinum spark plugs. Even in my 7 I don't run them anymore.
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
TeslaMSI
Dec 10, 2015 01:10 AM
DVerdeyen
Sep 13, 2015 11:19 AM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
