car won't start
Old Nov 21, 2007 | 01:48 PM
Jeison's Avatar
Unhappy car won't start
-9 and the 8 won't start anyone else having this problem, and have any solutions on how to have it start when it actually gets cold??? (I let it sit for about 2 days)
Old Nov 21, 2007 | 02:15 PM
wcs's Avatar
wcs
no agenda
I've never had a problem.
How many km's on it?
What year?
Do you have the latest flash?
How about the upgraded starter?
inquiring minds wanna know
Old Nov 21, 2007 | 02:43 PM
Jeison's Avatar
60,000 km, 04 manual
Old Nov 21, 2007 | 02:46 PM
Rems31's Avatar
and what about the last two questions
Old Nov 21, 2007 | 02:47 PM
wcs's Avatar
wcs
no agenda
OK well if you haven't done so already there are a load of TSB's for the 04 models.
Like
Upgraded starter
Computer reflash to help prevent flooding
Brake pads
Exhaust heat shield to prevent your car from catching on fire
And a custom beer tap of your choice.
Do you know if you've had any of these done?
Link to TSB -> https://www.rx8club.com/series-i-trouble-shooting-95/technical-service-bulletins-tsbs-recalls-rx-8-a-14453/
Read through the Issues and Problems area -> https://www.rx8club.com/series-i-trouble-shooting-95/
And remember search my friend ... search
Old Nov 21, 2007 | 03:26 PM
herbert's Avatar
Describe how it's not starting. Is it cranking but just not turning over? Is it not cranking? Did you shut it down with the engine cold the last time you had it running?
On some days right now, my car is taking a full 10 secs of cranking before it turns over and starts. I'm just letting it crank until it starts but 10 secs is a long, agonizing time. I've got spark plugs on order but waiting for them to get here to see if they make a diff. I've an 04 MT with about 57K on it.
Old Nov 21, 2007 | 03:31 PM
StealthTL's Avatar
Metatron
I'm a little north of you, and I use Esso XD-3 0W30 oil in winter - cranks faster, starts (relatively) quickly even at -40*
I have an adhesive 200watt pan heater, for the REALLY cold days!
S
Old Nov 21, 2007 | 03:41 PM
Jeison's Avatar
bought the car used, no idea if it's had any of that done, never turned it off cold, and i cranks but does not start... just had oil change done for 5-30 oil... how much is an oil pan heater??
Old Nov 21, 2007 | 03:59 PM
early 30's crisis's Avatar
destination anywhere..
^^ I've started mine in -32C and it fired up like a champ.. although that was last winter, this one might be a different story..
Old Nov 21, 2007 | 04:27 PM
philsbluerx8's Avatar
the recall also includes a new battery; i guess yours hasnt done it, just print off the file and go to dealership. just in case if they dont know about the recall.....
Old Nov 21, 2007 | 04:37 PM
Jeison's Avatar
and where do I go to get the file???? (if I can get the car started to get to the dealer :P)
Old Nov 21, 2007 | 05:22 PM
wcs's Avatar
wcs
no agenda
oh boy .... left click mouse click on link, click file menu then click print.
engine cranks no start : http://www.finishlineperformance.com...48-06-1691.pdf
Battery Replacement : http://www.finishlineperformance.com...42-04-1429.pdf
Ignition Coil Inspection : http://www.finishlineperformance.com...16-07-1793.pdf
Thermal Damage recall letter: http://www.finishlineperformance.com...RecallFuel.pdf
Thermal Damage inspection: http://www.finishlineperformance.com.../pdf/3305G.pdf
Get your parents to drive you to the dealership.
Old Nov 21, 2007 | 09:34 PM
Jeison's Avatar
well I just checked my car's install date, and it's nov 2003, but under the hood it says the following modifications have been performed N232-18881-N anybody know what that means...
Old Nov 21, 2007 | 11:46 PM
Jeison's Avatar
p.s. is there any way I can tell if I've had any of these things done... (upgraded starter for 1) or not really..
Old Nov 22, 2007 | 03:08 AM
BlueFrenzy's Avatar
Rotary Powered Decepticon
I believe that sticker tells us that you have had at least the "N" flash but we're upto like RSTUV ... anyways, get the new recall 4206F at the dealership where they will check the spark plugs, compression, along with all the other old stuff (basically what WCS listed for you).
Now when you say it doesn't start, how long are you cranking. I've found that in -30C weather, it needed about 5-8 seconds of cranking before it fired up. So if you're cranking for only a second, try longer.
Old Nov 22, 2007 | 07:07 AM
wcs's Avatar
wcs
no agenda
<start Breast feed>
Page 7 or 8 (auto or manual tranny) of this document describes how to determine if your starter is eligible for replacement.
You obviously didn't read any of the links I gave you because this was the first pdf link.
Dude don't take this the wrong way but you need to do a little work yourself here. Your gonna **** ppl off by not reading the links ppl are giving you.
I also believe that if you give the dealership the VIN of your 8 they can look it up in their database.
You can also look to see what the rpm is during starting. This should give you a good idea if it's a old style starter or the upgraded starter. I don't know off the top of my head what the rpm's are. I will let you do a search for that.
<end Breast feed>
Old Nov 22, 2007 | 10:24 AM
Rems31's Avatar
^^^^ Let the flaming commence if the next question he asks is answered in those links
Old Nov 22, 2007 | 11:31 AM
climacus's Avatar
If it cranks over but does not start, then your engine is probably flooded. Try the deflooding procedure (gas pedal to the floor, crank for 10 seconds, then turn off ignition and try starting the car again).
Old Nov 23, 2007 | 03:18 PM
wcs's Avatar
wcs
no agenda
I hope he found what he needed and I didn't scare him away.
My apologizes if I was a little curt.
Old Nov 24, 2007 | 02:18 AM
Jeison's Avatar
nah had it coming for only reading some of the bulletins :p and I got it started, so now I gotta take it to the city on my next day off (I live 2 hours from the nearest dealer), problem now is the dealer said that if it's off warranty it doesn't matter and I'd have to pay anyways (gotta check the VIN to find date of sale)
Old Mar 11, 2008 | 12:01 AM
Jeison's Avatar
Another dumb problem... When I drive the RX-8 and it's totally warm (needle @ 1/2 way on the dial), and I turn the car off, it will not turn on again until the car has cooled some, it cranks and gets to the threshold of starting but won't actually turn over (starts w/ boost though)
Quick Recap of my car from previous posts:
04 MT
63,000 km's
According to Mazda all TSB's done (except the beer tap of course)
and for the record an oil pan heater saved my *** for the winter, but before I got it put in I had to get a fair amount of boosts, and I searched but could not find anyone with this specific problem, just engine floods, and I let my car run for a min. of 15 mins every time I drive
Thanks in advance, and if I get Flamed, at least post your opinion somewhere in the flame!
Old Mar 14, 2008 | 04:31 PM
vincentlyw's Avatar
VIN-7
I think it is the "fuel flooding" problem, because my car had this problem once.
Old Mar 15, 2008 | 08:55 AM
wcs's Avatar
wcs
no agenda
??? Got me that's strange...
Clarify for me please. Do you mean it literally will not do anything when it's hot or it turns over but will not start?
Really I don't know why I'm asking b/c I don't have an answer either way.
<shrug>
However if I was you I would look at getting a new set of coils. With 63k on the originals they are bound to need replacing.
Old Mar 15, 2008 | 10:20 AM
Jeison's Avatar
it will turn over, but not start, it cranks @ like 7 or 8 hundred RPM but just doesn't catch... it's kind of annoying because I was trying to teach someone to drive standard, and she stalled and we had to wait like 15 mins before going anywheres again
Old Mar 15, 2008 | 11:44 AM
04 MT
63,000 km's
You might want to check the battery.....If it starts with a boost your OEM battery is probably toast. If you've killed it and boosted it a # of times in the Sask winter..It probably never re-charged properly....Plus if you're on the original at 63K...you likely have the end of the battery life anyway
