midpipe install
Old Nov 20, 2007 | 05:44 PM
joshk118's Avatar
midpipe install
what is the freaking trick to getting the stock cat out of the rubber hangers? is it possible to just cut them off because i wont be using them when i put on my midpipe.
also, how do you get a bolt out if the nut is stripped just a little?
Old Nov 20, 2007 | 05:59 PM
Nopstnz's Avatar
Haha, this took me forever as well. Get some wd40 or some lube and soak that rubber puppy down. For the bolts, make absolutly postively sure you have the right size wrench, one size to small won't fit, too big will strip(I think its somewhere between 13-17 mm, then use a breaker bar on the wrench and you should be able to get the nuts off with some elbow grease. Also, lube them up too!
Or, if it is stripped really bad, you could alwasy have a shop take it off for you in two seconds. I had to get that done when I stripped my alternator bolt.
Old Nov 20, 2007 | 06:00 PM
Spinning Sushi's Avatar
I <3 Sushi
I used Dawn Dishwasher soap and two screwdrivers to get it off the rubber hangers
Old Nov 20, 2007 | 06:04 PM
joshk118's Avatar
ok awesome thanks guys i'll go see if i can get it off.
Old Nov 20, 2007 | 06:36 PM
joshk118's Avatar
ok awesome the wd40 worked for the rubber hanger but now im pretty sure i have a stripped nut that connects the front of the cat to the header. i am using a 9/16 wrench and the nut is on there so tight i cant get it to even budge. i already got one of the front ones out but there are 2 more and the 3rd one is hard to get to. i want to get the stripped one out first so i dont mess up my wrench so much that the 3rd one is a bitch to get out. any suggestions? i really dont wanna take it to a shop just for them to cut the bolt out because i already have all of the other bolts out...
Old Nov 20, 2007 | 06:42 PM
chetrickerman's Avatar
vice grips?
Old Nov 20, 2007 | 06:47 PM
joshk118's Avatar
what is a vice grip?
Old Nov 20, 2007 | 06:52 PM
joshk118's Avatar
nevermind i google-image searched it. i think i've got one. sort of like a monkey wrench? i'll go try that.
Old Nov 20, 2007 | 07:03 PM
joshk118's Avatar
ok nevermind haha i dont even have one but it is definately stripped..
is there any other way to get this stupid thing off? i can go buy a new bolt i just need to get it out so i can take the cat off.
Old Nov 20, 2007 | 07:09 PM
joshk118's Avatar
how tough would it be to just cut the nut off? haha
Old Nov 20, 2007 | 07:15 PM
if it is the only bolt on there, and you can move the cat, use the cat as a breaker bar to bend and break the bolt, otherwise, just take a sawsall to cut it right off. i will be doing this in a couple days, i hope my bolts dont give me trouble
Old Nov 20, 2007 | 07:44 PM
joshk118's Avatar
well i have 2 bolts left so i guess i'll have to saw through it.
Old Nov 21, 2007 | 06:56 AM
Nopstnz's Avatar
Or if you don't want to go to a shop, just ask someone you know locally who has the tools for this kind of stuff, I'm sure they'd be more than willing to help you, I had to do that a few times when I didn't have the right size wrench or whatever.
Old Nov 21, 2007 | 11:04 AM
joshk118's Avatar
ok, what exactly is needed to cut a bolt off without damaging the parts around it?
Old Nov 21, 2007 | 11:09 AM
a saw and a steady strong hand
Old Nov 21, 2007 | 12:38 PM
that thing sounds like it hurts, im pretty sure you dont have to buy one of those, just **** off a woman enough.
JimmyBlack
273
Feb 10, 2020 10:23 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
br0wm
Oct 24, 2015 11:06 PM
yapakanichi
Sep 25, 2015 07:55 PM
