View Full Version : How to Power up a DVD player + LCD screen???
zzzzwong 11-19-2007, 03:36 PM i'm planning on integrating a DVD player + LCD screen into my car's audio system...
how should i suppose to power them up???
also.. am i buying the right things for my "sound" connections?
from mazdaparts:
P.I.E. MAZ/PC-ALP Aux Input Converter (http://www.mazdaparts.com/ProductDetail.jsp?LISTID=5050000-1154409213) + PIE ALP/M-RCA (http://www.mazdaparts.com/ProductDetail.jsp?LISTID=5060000-1154409214) + ground loop insolator
OR from sylfex:
aux mod (http://www.sylfex.com/products/AuxMod/) + RCA cable + ground insolator (http://www.radioshack.com/product/index.jsp?productId=2062214)
any help or suggestions would be great~!!!!
thx~!!!!!!!!!!!!
zzzzwong 11-19-2007, 03:46 PM also i'm planning on installing a stand alone nav unit later on...
is there a way for both the dvd player+nav to share the audio of the car?
thx~!!!
WikkedOne 11-19-2007, 03:47 PM you should be able to use the power going to your HU now - or the power going to the cig lighter..
the auxmod is the cheaper / easier way to go..
have you thought about getting the corksport kit and a good HU that does DVD and Nav and everything else you would need? sirius/bluetooth/XM Navtraffic/MP3 music/etc... etc...
Fortunate Few 11-19-2007, 06:32 PM im also doing the DVD / LCD thing like this
http://myspacetv.com/index.cfm?fuseaction=vids.individual&videoid=2941999
i have no idea how to do it yet but im buying the parts with in the next month or so.
Jose13b 11-19-2007, 06:52 PM you should be able to use the power going to your HU now - or the power going to the cig lighter..
be carefull if the cig lighter has to many amps that will burn you stuff out..use the power behind the radio test the wires with a volt meter
zzzzwong 11-20-2007, 02:44 AM im also doing the DVD / LCD thing like this
www.myspace.com/index.cfm?fu...D=1 266082637
hmmmm the link is weird.... can u post it again?
Fortunate Few 11-20-2007, 02:47 AM hmmmm the link is weird.... can u post it again?
yeah sorry, here it is
zzzzwong 11-20-2007, 02:57 AM you should be able to use the power going to your HU now
does it mean i have to cut and solder anything?...
can u describe it more specificly thx~
sorry i'm totally a nooob on this....>.<"
if anyone have ever done this pls share their diy~~~
any pix would help me a looot ~0~
this is harder than i thought
isn't there just a simple converter that will convert the car power into dvd-player's and lcd screen's usable power = =? sigh...
laythor 11-20-2007, 02:59 AM search for corksport and you'll find pretty much all your answers in those threads. Not saying you have to go the corksport route, but the guys here who have installed them have posted some pretty extensive information.
zzzzwong 11-20-2007, 03:03 AM the auxmod is the cheaper / easier way to go..
is there any sound quality difference between Mazdaparts' P.I.E. MAZ/PC-ALP Aux Input Converter and sylfex's aux mod ?
i'm using the retractable LCD holder (http://www.mazdaparts.com/ProductDetail.jsp?LISTID=5250000-1159943707)
i want to keep everything as stock as possible:uhh:
zzzzwong 11-20-2007, 03:06 AM search for corksport and you'll find pretty much all your answers in those threads. Not saying you have to go the corksport route, but the guys here who have installed them have posted some pretty extensive information.
oooooo icic~
why didn't i think of that!@@
okiz i'll keep on looking~
thx!
truemagellen 11-20-2007, 10:18 PM You can easily power it from the lighter but I wouldn't recommend it not becauese of the amps but the high level of noise...more AMPs will not damage anything...it is more volts that causes damage or in some circuits a drop in voltage.
You can easily add a fuse to the cabin fuse box by using a 'mini add-a-fuse' which splits the line and provides a holder for the displaced fuse and the new fuse.
Then I would ground it directly to the battery with a fairly large wire to prevent noise. The RX-8's ground is notoriously bad due to many aluminum panels, metal adhesives instead of welding, and more.
And of course I recommend the PIE over the syflex aux mod, especially if you have a tape or MD drive. The reason why I recommend the PIE is that it comes in a self contained box that uses a port that is not in use unless you have Sat radio...plus it works flawlessly, noise free. A ground loop isolator is simply a bandaid on a much larger problem.
I'm glad zzzzwong got his retractable nav hooked in...the pictures I've seen from the setups looks great. Keep them coming it is fun to see the different setups, dvd players, carPCs, and video game systems :)!
zzzzwong 11-21-2007, 01:47 AM i consulted a local audio shop today....
we talked a bit and had an order list done
i was surprised that they didn't request for any power wire @_@
so i asked the guy about how they usually power lcd+dvd+nav up...
he said he doesn't need a power wire... usually he tabs the wires into the radio harness for power.....
hmmmm... then i asked him how much is the installation fee: $800 CAD !!!!! wow~
i kno it doesn't worth it??
becuz i believe that i can do all of the installations except .....
just how do i power them up!??!? >.< sorry
i got most of the idea but i'm so frustrated
i mean wut exactly should i do
can anyone explain it step by step?....or any diy pix would be greaaat >.<!!!!
and thx to everyone who helped so far!!!
thx!
Jose13b 11-21-2007, 05:51 PM 800 tell him to kiss you ASS! where do you live am in jersey I will do it for free
I do alarm stuff for a living
Jose13b 11-21-2007, 05:53 PM yeah sorry, here it is
hey where did you get that dvd player what model is it... nice set up did you cut that whole in the dash
gotrotary 11-21-2007, 11:53 PM personally, i would run a 10 gauge power wire to power up anything directly to the battery. Just make it safe. There should be a grommet of some sort or somethin to get the power wire through the firewall pretty easily on the driver side. Hope this helps.
Fortunate Few 11-22-2007, 03:16 AM hey where did you get that dvd player what model is it... nice set up did you cut that whole in the dash
i didnt do it yet. someone on the board did. look for a thread called my lcd install. its on the first or second page. its a pyle 1/2 din and a pyle 7" lcd and yeah he cut a hole and made a custom fiberglass thingy disguise the gap.
zzzzwong 11-22-2007, 05:14 AM hey where did you get that dvd player what model is it... nice set up did you cut that whole in the dash
itz this~
http://www.pyleaudio.com/itemdetail.asp?model=PLTVD7%2E5N
zzzzwong 11-22-2007, 05:19 AM 800 tell him to kiss you ASS! where do you live am in jersey I will do it for free
sighhhh to bad i'm in vancouver =___="""
Jose13b 08-21-2008, 08:25 PM i didnt do it yet. someone on the board did. look for a thread called my lcd install. its on the first or second page. its a pyle 1/2 din and a pyle 7" lcd and yeah he cut a hole and made a custom fiberglass thingy disguise the gap.
where is the install link
J_Owens 08-27-2008, 11:36 PM dude that setup is fuckin sick
Fortunate Few 08-28-2008, 12:20 AM where is the install link
just search my lcd install.
oh ps. dont order from ebay you'll get the wrong dvd player. i bought the stuff and returned it all once i got the wrong dvd player i was pissed.:rant: :banghead:
