View Full Version : Cel #p0506
newcastle
11-18-2007, 07:48 PM
About 2 weeks ago a CEL popped up. With Jedi54 recently purchased software we diagnosed the 8 with CEL #P0506 (below normal idle speed). The CEL would go on and off and I couldn't identify a pattern.
A week after (car was running fine so I didn't see an immediate need to drop it off at the dealer) the diagnosis I had the dealer look at it. They said that they couldn't properly diagnose the vehicle due to the aftermarket intake (Racing Beat with ram air duct) and that I would need to reinstall the stock to properly identify the cause of this CEL however, they did pull up the code which matched what Jedi54 had on his software.
Well I decided to do some research and discovered the following causes that may have triggered CEL #P0506
1) MAF
2) IAC
3) Intake Leak
4) Exhaust Resistriction
I decided to tackle the MAF being that it's simple and probably needs it. I purchased some CRC MAF cleaner at my local auto parts store and cleaned the IAT and MAF resistors. So far the CEL hasn't reared it's ugly head. I'll keep you informed. See MAF pics below.
Before - IAT Sensor
http://img215.imageshack.us/img215/2491/img0637hk1.jpg (http://imageshack.us)
After - IAT Sensor (sorry about poor pic, couldn't get the focus to work)
http://img525.imageshack.us/img525/4630/img0643mz6.jpg (http://imageshack.us)
Before - MAF Resistors
http://img215.imageshack.us/img215/7618/img0640sk3.jpg (http://imageshack.us)
Jedi54
11-18-2007, 09:44 PM
I'm curious to see if this helps the CEL.
nycgps
11-18-2007, 11:43 PM
Thats some *freaking* dirty IAT sensor !!!!!!!!!
wow .... this is actually the first time Im seeing such dirty sensor :)
I havent clean mine for couple K miles but still clean (no dirty that I can see).
Jedi54
11-19-2007, 01:49 PM
I know you'd mentioned you usually got the CEL in the mornings, any luck this morning?
tajabaho1
11-19-2007, 01:55 PM
god damn, thanks man, I'm gonna check my MAF today too, it might be this problem also, see if it goes away
Jedi54
11-19-2007, 02:05 PM
random thought: odd how P0506 isn't listed in the RX-8 service Manual. :scratchhe:
newcastle
11-19-2007, 07:52 PM
CEL popped back up :rant: I'll have you clear the code later this week Jedi. If that doesn't work i'll have to install the stock box and have the dealer fix it.
newcastle
11-19-2007, 07:53 PM
First time cleaning the MAF sensor and I have 43k miles.
Charles R. Hill
11-19-2007, 09:41 PM
Take your accordion hose/intake duct off and try cleaning the TB. If the MAF was that dirty how about the TB?
nycgps
11-19-2007, 10:48 PM
I think you should check your air filteration. There is NO WAY it could be that dirty. Unless you havent clean it for the life of your car.
Jedi54
11-19-2007, 10:57 PM
we cleaned Newcastle's Ram Air intake about 6-7 months ago. Maybe ALL the ashes during the recent fires in CA messed things up a bit
tajabaho1
11-19-2007, 11:10 PM
well I'll tell u this much my MAF sensor was also as dirty as his, and I cleaned it and now the problem seems to be better too
nycgps
11-20-2007, 12:34 AM
really ...
Well, if thats the case, you guys know about the dust. shouldnt you guys clean it more often ? both filter and whatever.
Razz1
11-20-2007, 10:28 AM
Do not take it to the dealer. Just disconnect the battery for a few minutes and rest the PCM.
Re-tighten the MAF tube and all connections.
Check that Red plug under the throttle body. It may be causing an air leak.
They have een known to get loose.
Most likey that's the problem. Use silcone to secure it on.
max5roadster
11-20-2007, 11:17 AM
Pretty sure the brown node that you see in the first 2 pics is not the MAF Sensor, but the intake temp sensor. IIRC, the MAF sensor is the wire section you show in the 3rd pic. It didn't look too bad in that pic.
nycgps
11-20-2007, 02:51 PM
most of us know that. :)
but the point is, if his temp sensor has dirt like that, imagine how does it look like on those 2 wires inside the unit ...
Jedi54
11-20-2007, 04:53 PM
Do not take it to the dealer. Just disconnect the battery for a few minutes and rest the PCM..
No need for that, I used my Scanaylzer to reset the code a few weeks ago, now it's back.
I'm assuming this got done when he put it back on??
Good suggestion Razz, that damn thing does get loose after a while. (it's for those who have the RB intake, which Newcastle does)
Jedi54
11-20-2007, 06:19 PM
I'll look into this, thanks Ray
newcastle
11-20-2007, 07:32 PM
Great suggestion! I'll work on that this week.
newcastle
11-20-2007, 07:38 PM
Of course.
I checked that out already and it's very secure.
Jedi54
11-20-2007, 07:39 PM
we need to clear your CEL again to make sure we can properly troubleshoot this.
I should start charging locals for pulling / clearing codes. :D: (j/k)
newcastle
11-24-2007, 10:54 PM
Update: I cleaned the throttle body and air filter (it did have a thick black ring encompassing the butterfly valve which was a PITA to clean). Unfortunatly it didn't fix the CEL. I'll be removing the RB and installing the stock intake so the dealer will correct the issue. I'll keep you folks updated.
Jedi54
11-24-2007, 11:23 PM
good luck with the dealership! Hopefully with the stock intake going back in they'll have no more excuses and will actually fix this
newcastle
12-06-2007, 09:19 PM
Update: Dealer said I had a bad TB. Got a new TB under warranty however, the they said that the RB CAI may have generated the problem. If this problem were to occur again with the RB then they will not cover it under warranty. Personally i'm perplexed as to how the RB CAI can cause TB failure. In order to mitigate future headaches/pissing matches I have decided to simply install the stock intake. Car idles much smoother and runs great now.
Jedi54
12-06-2007, 09:26 PM
you're not going to leave the stock intake in there for long, are you????
There's NO way the RB CAI damaged your TB.
newcastle
12-08-2007, 12:22 AM
Unfortunatly my CAI is going back to stock until my warranty expires. I concur that the RB didn't cause the TB failure however, I don't have the time or motivation to get into a pissing match with the dealer. So....new trans and TB, I suppose an engine is next.
