Trans fluid and diff fluid
Old Nov 18, 2007 | 06:05 PM
R888's Avatar
WedsSport Member
Arrow Trans fluid and diff fluid
I am going to change the trans fluid this week with AMSOIL, the auto transmission is 8.7 liters.
I will post back a review this weekend.
Just wondering is there a diff fluid for the auto tranny? If yes, what would you guys recommend?
Old Nov 18, 2007 | 07:11 PM
Jasonawojo's Avatar
I believe the diff on the auto is essentially the same as the one on the manual, except the ratio. Only exception would be the very base model auto that doesn't have an LSD. For my diff I used Redline 75w90 Gear Oil, and Royal Purple Max Gear 75w90 is also good from what I've read on here.
Old Nov 18, 2007 | 08:38 PM
R888's Avatar
WedsSport Member
Thanks for your reply.
Whats the best stuff for diff fluid for auto tranny? should I use the same type of what manual use even the ratio is different?
Old Nov 18, 2007 | 08:54 PM
Jasonawojo's Avatar
The diff fluid (1.3l capacity) is entirely separate from the transmission, and the ratio doesn't matter in regards to the fluid. Sorry for confusion there.
You'd want to use a 90 weight gear oil meeting the GL-5 standard according to 10-5 in the owner's manual. Both the Redline 75w90 gear oil and Royal Purple Max Gear 75w90 meet these requirements. There are also many other gear oils out there that would do, but those are the two I read about on here. Search and you'll see either is fine, use whatever you can get.
Old Nov 19, 2007 | 12:50 PM
mdw1000's Avatar
I'll snap his neck.
My local Autozone only had the Mobil 1 when I went in to get the fluid for my new diff. Used that and so far it has worked fine. If I had more time I might have tried to find the RL or RP. But I had used Mobil1 on my pickup's diff with no problems, so I really wasn't worried.
Old Nov 21, 2007 | 09:49 PM
R888's Avatar
WedsSport Member
Thanks for the reply.
was the RP Max Gear 75w90 is synethic? Can I use that or the non-synethic?
Old Nov 21, 2007 | 10:01 PM
Jasonawojo's Avatar
The Max Gear is synthetic, as is Redline, and the Mobil1 mdw1000 mentioned (I assume it is this?). I haven't really heard of using non-synthetic in the diff, I believe even the OEM fluid is synthetic.
Old Nov 21, 2007 | 10:02 PM
R888's Avatar
WedsSport Member
Thanks buddie!
Btw, I did an oil change with Castrol 5w30. It feels good!!!!!
SMOOTH!!!!
Old Nov 21, 2007 | 10:03 PM
R888's Avatar
WedsSport Member
So I need 2 bottle eh?
Old Nov 21, 2007 | 10:07 PM
Jasonawojo's Avatar
For the diff fluid, yah. Suppose to take 1.3l, but you'll probably end up using 1.5 or so after spilling some and such.
Old Nov 21, 2007 | 10:09 PM
RotorChase's Avatar
where do you guys get the gasket for the pan? the dealer didnt even pull it up without the pan along with. and autozone/orilly's didnt have it either??
Old Nov 21, 2007 | 10:18 PM
Jasonawojo's Avatar
I found this on Onlinemazdaparts.com. They have a gasket and filter there under Automatic Transmission, not entirely sure if thats it though as I don't have an AT. http://www.trademotion.com/partlocat...layCatalogid=0
Old Nov 21, 2007 | 10:19 PM
R888's Avatar
WedsSport Member
Pan gasket? do we need one when doing Gear fluid change or the ATF fluid change?
Old Nov 21, 2007 | 10:33 PM
Jasonawojo's Avatar
ATF, the diff just uses a drain plug and fill plug.
This is the only AT fluid DIY that I found on here, and on there it mentions you needing a new AT pan gasket in order to change the fluid as you drop the AT fluid pan to get the fluid out. Not sure if there is any other way of doing it..?
Old Nov 22, 2007 | 11:56 AM
mdw1000's Avatar
I'll snap his neck.
Yup, that links to the Mobil1 that I used.
Old Nov 22, 2007 | 04:36 PM
cajunrx8's Avatar
Rotary Crawfish
Ok I am just doing this for clairity.
The Diff oil is differential oil, axle oil, rear end oil. 75w or higher.
The Transmission oil is totally different and has to be changed by removing the trans oil pan and gasket.
I just want it clear what the OP was asking about since some terms used were kinda fuzzy.
Old Nov 24, 2007 | 07:37 PM
R888's Avatar
WedsSport Member
For automatic GASKET - OIL PAN
Part # BW60-19-835
Mazda dealership
Old Nov 29, 2007 | 08:08 PM
R888's Avatar
WedsSport Member
THis winter I have already doing major oil changed for my car
10 x AMSOIL ATF @ $11.99 each (you only need 9.5 bottle, only 8.7 liter needed)
2 x Royal Purple @ $12.99 each (you only need 1 1/4 bottle then is full)
1 x Castol 5W30 @ $13.99 each
All things have been changed, there is a difference of accerlation but not a big big change. Thats all I have to say.
Old Nov 29, 2007 | 08:36 PM
Jasonawojo's Avatar
Sounds good, how hard did changing the ATF turn out being?
Old Nov 29, 2007 | 08:54 PM
R888's Avatar
WedsSport Member
The guy didn't take off the oil pan, he took off the hose connector instead and then hoock up his flush machine relasing all the old oil and it was dark smelly!!! he hooked up the return hose for the new oil.
Then he pour all 9.5 bottles of AMSOIL in the machine and when the machine push the old oil out the new ones get in....
NO NEED TO TAKE OFF THE PAN...but he said he was firm that the old oil gets out competley. =)
I think is a must for 50k car, it brought back the memory when I first drive it on the road.
Old Dec 9, 2007 | 12:29 PM
R888's Avatar
WedsSport Member
After 2 weeks, I don't think the AMSOIL make a big difference, but the royal purple differntial fuild did.
Old Dec 19, 2007 | 08:43 PM
R888's Avatar
WedsSport Member
After months now, still feel the difference. Maybe was it because its winter?
Old Dec 19, 2007 | 08:58 PM
Atilla's Avatar
I am THAT guy
Hey thanks for the write up -
I'm about to get a tranny flush n' replace it with RP Max by the end of the month only because i found a place that has it in stock for about $8 U.S. - i'll be sure to post up my results on here too.
Old Jan 6, 2008 | 10:22 PM
R888's Avatar
WedsSport Member
whts up with the RB?
My engine is getting loud because I changed to 5W30. Everything is still good....
theblinkof
Oct 4, 2023 05:24 PM
airlive
Jun 28, 2020 07:46 AM
bosstin87
Oct 5, 2015 06:52 AM
XianUnix
Sep 29, 2015 03:48 PM
