Krazyk8
11-15-2007, 09:24 AM
Just wondering if I could convert the holgen headlights to the factory HIDs, is ther a harness already in the car for it or what am I looking at?
View Full Version : converting to HIDs Krazyk8 11-15-2007, 09:24 AM Just wondering if I could convert the holgen headlights to the factory HIDs, is ther a harness already in the car for it or what am I looking at? dEEpsEa 11-17-2007, 02:29 AM You need more than just changing bulbs. HIDs need ballasts which generate very high volts to 'force' Xenon to produce lights. So you need a whole HID kit if you don't have factory HIDs. Krazyk8 11-19-2007, 09:40 AM I know this. I was wondering if I buy the stock ballast and bulbs and what ever elts. Do I need to tag it in to the light harness or is ther alreaddy a connector for the ballast in the harness. Because many maufactures just make one harness and hide the connectors that are not in use. gregs 11-19-2007, 10:38 AM i bought mine here at this site, very easy to install and came with all the necessary parts needed to do the swap, dont get the ebay ones they will not fit because of the size of the universal bulb, the swap took me about 35-40 start to finish http://www.therpmstore.com/index.php Rote8 11-23-2007, 09:42 PM i bought mine here at this site, very easy to install and came with all the necessary parts needed to do the swap, dont get the ebay ones they will not fit because of the size of the universal bulb, the swap took me about 35-40 start to finish http://www.therpmstore.com/index.php Page at that link has too many options, what parts did you actually buy? gregs 11-23-2007, 11:13 PM http://www.therpmstore.com/product_info.php?cPath=57&products_id=38 this is the one i got Rote8 11-24-2007, 09:24 AM http://www.therpmstore.com/product_info.php?cPath=57&products_id=38 this is the one i got In the options, at the bottom of the page, what "Bulb Type" did you choose: The "Stock" H7 low beam type bulb, or the "D2" type (Like the factory HID cars)?:banghead: gregs 11-24-2007, 01:19 PM i got the h7 low beam option only |
