View Full Version : Air bubbles in coolant tank
Footman
11-11-2007, 08:16 AM
I think this is related to the "Sand/marble in the blender" sound. I bought the car just a month ago, it's properly broken in now, and yes it has that sound at HIGH RPM's at WOT. When I bought the car, I remember the coolant tank did not have any bubbles.
Now when I look, there are air bubbles inside the coolant tank. Do I just simply open the cap and idle my engine to let the air bubbles go away?
staticlag
11-11-2007, 01:31 PM
not unless you want your cooling system to be inffective and risk major burns.
Maybe your car is overheating. are you revving it in place a lot?
Razz1
11-11-2007, 01:35 PM
Yes you can do that to remove air bubbles. But the car must be cold before you do this. Let it run until she begins to overheat.
nycgps
11-11-2007, 07:20 PM
if you want to bleed it *better*, park it at some inclined, the head facing UP, let it cool off, open the cap, let it idle until the temp reach 1/2 way, then let it idle for maybe another couple of minutes, shut it off, see if the coolant level stays, if not, top it up a little, close the cap, be happy
Footman
11-11-2007, 08:32 PM
leaking housing seals on a brand new car???
Razz1
11-11-2007, 08:52 PM
HAY !
It's not a Toyota! No way he would have that problem.
nycgps
11-11-2007, 09:46 PM
I thought only Kia has that problem :)
Socket7
11-12-2007, 03:12 AM
i noticed the same strange sound at about 6 to 9k RPM at near WOT. sounds like plastic bb's bouncing around in a container (it actually sounds like its coming from the glovebox). it's always done this since i bought it. I think its normal, but I plan to ask the dealer about it when i take it in for my 6k mile service.
I don't think its related to coolant. :squint:
nycgps
11-12-2007, 08:06 AM
the sound came from the port opening.
Its normal, but some people found it to be annoying.
Im fine with it, actually I like the *dididididididididididd* sound :)
