blowinup
11-08-2007, 09:35 PM
Well it seems I went out of my service contract an or course now my neutral safety switch is faulty. Is this something I can do myself I have an ass load of tools but do I need to reset my computer? Also where is the switch located? :banghead:
Hey man im a new member also and i know how it sucks when you dont know what to do and no one helps...to the point now... I dont know where it is located but even if your service is out...i would check to see if that might of been a recall on your car...ive read a few site where it stated that many 8z have had a recall and that the neutral switch was one of the possible parts to go bad..ill try to find them site again and let you know...good luck
swoope
11-17-2007, 11:39 PM
they have been failing... mine is done.. you have to modify a socket or have the right sized crows foot to remove it... think it is on the drivers side of the tranny...
not easy to get to..
beers :beer:
RX8-Frontier
11-27-2008, 10:21 AM
To drag up an old thread...
I'm changing mine out today.
It's on the driver's side of the transmission.
To expand on what swoope said, to modify a socket to work, you'll need a 1-1/16" deep wall socket (either a 26mm or 27mm should fit as well, but the 1-1/6" is just perfect for the replacement one I have; check yours to be sure, 'cause there ought to be a metric size that's technically the "right" one. Cut out the side of it similiar to an injection socket so that the wire harness & connectors can come out the side. There's not a whole lot of space in there, so a wrench isn't gonna' cut it, most likely.
Make your socket look like this:
http://i.s.shopwiki.com/i/data/0x0/9/304/323/aHR0cDovL3d3dy5zZWFsZXkuY28udWsvaW1hZ2VzL3Byb2R1Y3 RzL1RodW1ibmFpbHMvU1gwMjUuanBn==.jpg
04RX8man
11-27-2008, 11:29 PM
yeah don't use one of your expensive good sockets if you have good one if ur gonna' cut a socket apart buy a cheap ass one from walmart or something don't use a snap-on or something....or a crowsfoot....
Anyone got pictures of the location of this neutral switch....?
TeamRX8
03-17-2009, 04:39 PM
upper rear driver side of the trans just forward of the powerframe mounting point (pic by Swoope)
http://www.rx8club.com/attachment.php?attachmentid=94500&d=1171856489
Razz1
03-17-2009, 08:23 PM
I wonder if you can buy a socket like this?
shazy
03-17-2009, 08:25 PM
Can you edit the picture and circle it?
