Can't decide
Old Oct 31, 2007 | 12:50 PM
Jethro Tull's Avatar
Living In The Past
Can't decide
I'm going to install protective mesh over my oil coolers and radiator. I can't decide if I should go buy a roll of mesh from the home improvement center and do it myself, or get something like the Racing Beat set (and just install it myself).
Looks like either way, the nose is coming off and I'd better set aside the better part of the day to do it.
Advice? Opinions either way?
Old Oct 31, 2007 | 01:00 PM
pussywillow1972's Avatar
I got the racing beat set after a rock took out my A/C condenser. Best $100 I've spent on the car. It took me about an hour to install them. Very easy to do and they came with very good instructions. That would be my vote.
Old Oct 31, 2007 | 01:02 PM
EDZRIDE's Avatar
2005 White GT
Go with the Racing Beat screens>
Living In The Past
^Only an hour, taking off the nose included? That's pretty convincing.
Old Oct 31, 2007 | 02:26 PM
Yup. Taking the nose off was a piece of cake. The only problem I ran into was disconnecting the side marker lights. I couldn't unclip them easily with my big mitts.
Old Oct 31, 2007 | 02:37 PM
Chris's Avatar
Turbo Member
well a huge sheet of mesh costs $5.00 you have to remove the bumper either way... I dont see how you cant decide
Old Oct 31, 2007 | 03:29 PM
dmc27's Avatar
doin' the bull dance
^ yup. and the "hardware cloth" has similar sized holes as the RB screens. Less cutting, painting (optional) and guess work getting the RB screens seems like the only upside. Cheaper by far to just hit the hardware store (Lowe's had the 'hardware cloth' in the outdoor/garden dept.)
IIRC, RB has the instructions for the screens as a download.
Edit: Yup. There's a link at the bottom of this page for the PDF instructions. It's only one page, so that should give you some idea how easy the process is.
Old Oct 31, 2007 | 10:54 PM
onephatguy's Avatar
18 month shelf life
I have the screens from RX8strakes.com and I think you can do it cheaper by yourself with better results. And it took about an hour.
Old Nov 1, 2007 | 08:18 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Spend some of that old money and get the Racing Beats. Install is about 20 minutes tops if you've taken the bumper off before, and 30 minutes if you haven't. They have rubber around the outside of the screens and they just slide right in. I did the radiator screen at the same time and both were a piece of cake.
Dave
Old Nov 1, 2007 | 08:21 AM
Spinning Sushi's Avatar
I <3 Sushi
I can take off the bumper in 10 mins I've done it so many times (at least once every two weeks) that I can do it with my eyes closed
Old Nov 1, 2007 | 08:23 AM
Mazurfer's Avatar
Ain't that the truth! I've had it off so many times it's ridiculous! First time I did it though I was nervous! Seems like you are taking the whole car apart, and then after the first time it's like "No big deal" at all.
Old Nov 1, 2007 | 08:28 AM
I <3 Sushi
LOL! Exactly how I felt the first time. There's basically only four screws on top (in the engine bay) and buncha gromlets to remove. It's that easy
Old Nov 1, 2007 | 08:45 AM
Ben98gs's Avatar
The "other RX8" owner
I am thinking about doing this, but I am going to do my own... I would hate to pay $100 for $5 worth of materials. Maybe that is just me though
Old Nov 1, 2007 | 08:55 AM
Mazurfer's Avatar
Either way...it's all good........the reason is obviously to protect the coolers, so it doesn't matter. Yeah, I could've done it for cheap and had it look good, but just not the path I chose to take.
Old Nov 1, 2007 | 09:16 AM
Ben98gs's Avatar
I agree... if it was more "reasonably" priced I would definitely probably pay a little extra for the convenience. But most I would be willing to pay for something like that is probably $40-50. But then again, I am cheap
Old Nov 1, 2007 | 09:35 AM
dmc27's Avatar
It's not even close to being cheap when the markup is that high! Cheap is saying no to $10 screens cuz you can get them for $8. Not paying a 90% markup is smart.
That's my story and I"m sticking to it.
Plus I will have ~ 90% of the roll of wire left to use for other things - like keeping my effin cats the hell away from the plants that need to come inside for the winter.
Old Nov 1, 2007 | 11:56 AM
Living In The Past
My boss has a racing Porsche and he uses a stailess steel mesh in all the new noses I make for his car. If I went "home brew" I'd lean toward the stainless mesh over the galvanized.
Those RB screens have a nice finished look that can't hurt the resale value of the car, not that I'd ever consider selling!
The car is about to go into winter storage so I'll have plenty of time to decide, as well as work on it.
Old Nov 19, 2007 | 11:44 AM
dmc27's Avatar
Did mine yesterday (finally) - do it yourself. It's ridiculously easy.
Old Nov 19, 2007 | 12:14 PM
reaper1's Avatar
I paid the hundred , but if I was to do it again I would do the Lowes or Home Depot one . Same crap and much cheaper. Once you take the front nose off you just measure and cut the size you need and screw them on . Took me about an hour .
Old Nov 19, 2007 | 07:00 PM
zerobio's Avatar
Atomic 8
I'm also going to get the racing beat ones and have RPM install them (I'm an idiot when it comes to doing stuff myself ... but I did my own clears!). But do they rust or anything?
Old Nov 20, 2007 | 10:42 AM
dmc27's Avatar
Do it yourself. Regardless of whether you buy the screens or not. Takes an hour (ish) and is very easy. If you were able to follow the instructions and put the corners on w/o any trouble, you can do the same for screens. (side note: had my Dad help me since he's got a garage. He refused to detach the bumper on each side and pop it back into place after b/c he didn't want to be responsible for any problems )
How much are they going to charge you to install?
Wire mesh = ~$10
Cut it, paint it (if you want) and spend an hour doing it. The satisfaction of the DIY is priceless, and it saves a couple hundred that can be used elsewhere.
Old Nov 20, 2007 | 11:28 AM
New Yorker's Avatar
I vote for the RB screens. When they arrived I was pleasantly surprised at the level of quality; I was expecting simple, kinda cheap-looking functional screens, but the quality of the screens, the rubber borders, and the way they simply slid right in was very impressive. Installed, they look impressive. Like something you'd find on a more expensive car.
My only concern is, are they restricting too much air and compromising the performance of the oil coolers?
Old Nov 20, 2007 | 11:38 AM
Huey52's Avatar
Registered Zoom Zoomer
I got the racing beat set Before a rock took out my A/C condenser. Concur, easy DIY.
Old Nov 20, 2007 | 11:41 AM
Uncivilizedracer's Avatar
Turbo SR20deT Son!
I say do it yourself and brand a your own name for the screen protectors - i did mine and it took a rock like a champ - no regrets
Old Nov 20, 2007 | 03:14 PM
dmc27's Avatar
Interesting. Price check, please.
Link to MazSport listing for screens.
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Quiggs321
Sep 30, 2015 05:34 PM
Ian_D
Rotary Swaps
Sep 23, 2015 11:22 AM
Hiroshima_RX
Sep 21, 2015 06:28 PM
