Puking Antifreeze
Old Oct 30, 2007 | 11:54 AM
2k4_8's Avatar
Puking Antifreeze
So, I read the forums and all the stuff I saw was on the water pumps leaking. I figured this was the issue so the last time I changed the oil, I ripped out the airbox and looked with a mirror etc, only to find the very minor leak (no puddles, but I can smell it very strong) is coming out the tube for overflow leaking onto the fan shroud. It was even overflowing when it was low and the low coolant light was on. I figured to start with the simple stuff and replaced a radiator cap. It seems to have helped, but not eliminated the problem as I still smell it sometimes. The car has never overheated according to the temp guage, what could be causing this?
Old Oct 30, 2007 | 11:58 AM
Rotary Inspired's Avatar
Rotared
Thats generally not a good sign. It sounds as though it is a coolant seal failure, and the exhaust gasses are getting into the cooling system. How many miles are on the motor?
Old Oct 30, 2007 | 12:10 PM
2k4_8's Avatar
Approx 22,500 miles on the motor. I also have what I believe is a contaminated catalytic converter that smells like crap, but as most know, the Mazda monkeys are told to tell everyone that it's just the fuel... One other detail that may help is that the idle doesn't sound as smooth as most of what I hear on you tube and such. It's pretty close but a little off, has a minor sort of stumble in it.
Last edited by 2k4_8; Oct 30, 2007 at 12:12 PM. Reason: Wording may have been confusing >.<
Old Nov 5, 2007 | 10:49 AM
2k4_8's Avatar
So....how does one go about finding out if that is the issue? If that is the case...would antifreeze also leak into the exhaust? Should I put some uv dye in the coolant and see if it comes out the exhaust? Also could that be the source of my contaminated cat?
Old Jan 6, 2008 | 06:25 PM
Keef's Avatar
the shit starter
I have close symptoms to what your talking about... On a cold start my car idles at 2,000 RPM's, but sounds like it's dying at 400 RPM because so much coolant is going into the combustion chamber... I'm confused about how to tell which specific part it is I need... My engine is dying, and I've never owned a rotary engine in my life She almost lived too 80,000
Edit: My coolant does not leak at all though, but does seem to be slowly becoming less and less...
Old Jan 7, 2008 | 11:57 AM
2k4_8's Avatar
I dunno, I think mine was just a bad rad cap. I would assume most mechanics might use a bore scope to check the comb chamber/rotor for signs of coolant.
Old Jan 7, 2008 | 01:06 PM
RCCAZ 1's Avatar
Best test is to pressurize the cooling system. If it holds pressure, chances are that you have a bad cap or leaky hose somewhere. However, if it fails the pressure test and the Dye test, it could be NEW MODA time.
Jesus Martinez
44
May 6, 2025 08:09 AM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Mane
Nov 20, 2015 12:16 PM
PotatoCannon
Sep 6, 2015 11:48 AM
foxyRoXy8
Aug 18, 2015 10:26 PM
