coils
Old Oct 27, 2007 | 07:28 AM
knightrider72's Avatar
knightrider
coils
I was having a cel 2 days ago.I wend to the shop and the laptop shows coil B p0352 manufalction.Cause i want to replace the coil by myself i wand to know the location of each coil when you see it from the passenger frond.So the numbers are
P0351-A
P0352-B
P0353-C
P0354-D
THIS ARE THE CODES AND L1 T1 L2 T2
Old Oct 27, 2007 | 07:45 AM
Jon316G's Avatar
Grasshopper
Not the best pic, but it shows you the locations for L/F, T/F, L/R, T/R and is shown looking at it from the driver's side.
Old Oct 27, 2007 | 07:55 AM
knightrider
thanks jon
Old Oct 28, 2007 | 12:01 AM
interesting,
as that code does not exist..
https://www.rx8club.com/series-i-tech-garage-22/rx-8-technical-info-cel-codes-pcm-pin-list-collision-guide-26291/
what year car, and what did you use to read the code????
Old Oct 28, 2007 | 12:46 AM
Those are Generic OBD-II code.
but, no way, all 4 of your coils died at the same time ?
Old Oct 29, 2007 | 12:40 PM
knightrider
yes you are right those codes does not exist i do my search thats why i ask you pepople if you know anything.My car is 04 mt and is inport from japan i dont know if that makes any diference.Anyway the diacnostic says that coil B primary secondary manufalction and the code was p0352-B
Old Oct 29, 2007 | 01:50 PM
Thats probably the Front Rotor Trailing Coil. Not 100% sure so dont quote me on that.
if OBD-II can detect the failure, it should be REALLY *bad *. change it all out.
Your car should experience really shitty engine respond and tons of misfires before the coil goes completely dead.
and, have you ever change your plugs? cuz if the coil goes bad, it might foul the plugs.
so get all 4 coils, about 100 bucks, not that bad.
Original coils came with all 04 and some 05 suck ***. not like the revised one are Day N night differents, but better than the original design.
Old Oct 29, 2007 | 02:48 PM
knightrider
Thanks a lot man.Can you provide me a side so i can order them.Here in cyprus the original ones cost believe it or not 700
Old Oct 29, 2007 | 02:51 PM
Err 700 ? Us Dollars ? for stock coils ?
HELL NO !
Im not sure if they ship it internationally, u can PM Jason @ OnlineMazdaParts User name is BAGMAN1 or PM Tommy @ RosenthalMazda user name here is RosenthalMazda
If they ship it Cyprus, Im sure it will cost nowhere near 700 bux.
Old Oct 29, 2007 | 02:53 PM
knightrider
Thanks man
Old Oct 29, 2007 | 02:55 PM
no problem man.
good luck.
Old Oct 29, 2007 | 03:27 PM
O'Renesis's Avatar
I cant help with those codes, not in any RX-8 manual I have. The usual code for misfires is P0301 and P0302. Parts are shipped worldwide from Onlinemazdaparts http://www.trademotion.com/partlocat...?siteid=214264 of which I can say are excellent people to deal with. For example RX-8 ignition coils are about $28 each.
Good luck with your problem, hope you get it fixed quickly.
Old Oct 31, 2007 | 05:52 AM
dasoviet's Avatar
Is it possible to have failed coils without having a CEL?
I experience very much misfires rough idles but no CEL?
I changed all coils 13k kms before along with a new set of spark plugs?
Most of the miles are in the city which in summer is about 50celsious.
Anw.
Old Oct 31, 2007 | 08:00 AM
You will not be able to find Generic OBD-II code in your manual, because you will see them in the OBD-II manual.
Anw.
It could be, because by the time OBD-II detects the failure, the coils should be in pretty *bad* shape.
Thats why Mazda has a guideline on how to check the coils with a multimeter.
Old Nov 5, 2007 | 09:54 PM
lennon's Avatar
I've been using mutimeter to test fault coil and new coil, but couldn't see any differents in point-to-point ohms...... I suspect my car is having coil problem but no CEL yet, misfire and jagged power dynoed at high rpm....
Old Nov 5, 2007 | 11:07 PM
Its just sad that the coil(s) failure are hard to detect. If it shows on the CEL, the coil(s) should be completely dead.
oh well. Im on my 2nd set of coils.
FubarI33t
Sep 28, 2015 08:45 PM
JAYDOH
Sep 24, 2015 01:54 PM
Sheldon24
Sep 21, 2015 04:53 PM
Vedivan1
Sep 18, 2015 12:39 PM
