View Full Version : Better Sound, Less Heat in Trunk, Quieter Ride
selmeralto
10-18-2003, 06:54 AM
I've made a simple and cheap modification that makes small but noticeable improvement in three areas. I bought some heat shield insulation from J.C. Whitney and lined the entire trunk (walls and floor) with it. The result is that the (Bose) system sounds a little tighter, the trunk (especially the floor) is much cooler so that I don't have to worry about things warming up on long trips, and the car is quieter.
The item number from J.C. Whitney is 25ZX0705N Heat Shield Insulation, 48" x 72" Sheet, $26.95.
One sheet was enough for the trunk with a little left over for bits in the cabin flooring. Actually, I bought two sheets and may do the entire cabin.
Please don't ask for pictures. I just cut the sheets up and layed them in there. Someday I'll find the time to rip out the carpeting and put it under the carpets.
RodsterinFL
10-18-2003, 06:59 AM
How about the cabin footwells. Noticeable improvement? This is what concerns me.
selmeralto
10-18-2003, 07:07 AM
So far I've only installed a scrap under the passenger side floor mat, on top of the carpet. It does seems to have helped there. I have yet to do either area in full.
The insulation is quite nifty: aluminum sheeting laminated to fibre tech padding. Easily cut with scizzors. Perhaps this link will work: http://www.jcwhitney.com/webapp/wcs/stores/servlet/NavView?Ntt=25ZX0705N%20&Ntk=AllTextSearchGroup&Nty=1&Ntx=mode+matchallany&Dn=0+111&D=25ZX0705N%20&Dx=mode+matchall&ss=10101&section=body&firstSearch=1&tmplframe=EndecaCategoryView&catalogId=10101&storeId=10101&langId=-1&URL=EndecaControllerView
selmeralto
10-18-2003, 07:29 AM
I might also add that I cut up a few inserts for the storage compartments on top of the tunnel.
SpacerX
10-18-2003, 08:24 AM
When I installed a new stereo system in my PGT I used the Dynamat insulation extensively -- made a huge difference in controlling temperatures and noise. I'm defeinitely planning to do the same for the 8 (when I get one!)
B-Nez
10-18-2003, 08:06 PM
selmeralto, do you know what the insulation material weighed?
selmeralto
10-18-2003, 09:45 PM
HI B-Nez,
The roll that covered the whole trunk area with a little left over for the passenger footwell weighed a little under 4 pounds.
got 8
10-18-2003, 09:48 PM
thank you for the info
the fe is somuch more quieter than my fd,
but i do plan on lining the entire car foot wells, tunnel, trunk, doors.
dont know if i should mess with the head linning as it is attached to the curtain airbag.
will post pics when process start.
selmeralto
10-18-2003, 09:53 PM
Thanks, Got 8. I'd look forward to seeing the pictures and to hearing about any unexpected problems or work-arounds.
