another intake question
Old Oct 24, 2007 | 11:12 PM
ne0lain's Avatar
where am I?
I have been searching the forum and couldn't find an answer to my question. Do you have to take off the front bumper everytime you need to clean the filter on the mazdaspeed cold air intake? I am getting the intake at cost b/c i work at a dealership, but if i have to take the bumper off every time i clean the filter it wouldn't be worth wild to me. any input would be great. thanks
Old Oct 24, 2007 | 11:21 PM
DefinitiveDetour's Avatar
which dealership...
Hook a brother up!!!
Old Oct 24, 2007 | 11:46 PM
ne0lain's Avatar
where am I?
mobile, al a little far for you to drive.
Old Oct 25, 2007 | 12:08 AM
Jon316G's Avatar
Grasshopper
Yes... but its not that hard.
Old Oct 25, 2007 | 09:53 AM
Chris's Avatar
Turbo Member
taking the bumper on off is easier than rotating tires IMO
Old Oct 25, 2007 | 10:16 PM
ne0lain's Avatar
where am I?
well, i will find out sat. I got the ms intake and the ms exhaust to put on.
Old Oct 25, 2007 | 11:03 PM
Jon316G's Avatar
Grasshopper
You won't find anything difficult with the MS intake installation, just remember to remove the VFAD and plug the inlet on the intake manifold where the VFAD vacuum line went. Also, make sure to keep the MAF sensor clean. May not be a bad idea to give it a little rinse with some contact cleaner or MAF cleaner that you can get at Autozone. I installed an AEM intake (which is the same design) and it came with pretty clear instructions. Not sure how the instructions are for the MS intake.
The exhaust isn't bad either (just depends on how rusted it is). Save yourself some trouble and use dish soap on the rubber grommets when removing/installing them onto the hangers.
Other than that, you should have no problems (hopefully)!
Old Oct 26, 2007 | 10:48 AM
Mike06's Avatar
Having to take off the front bumper much easier than your making it seem. Having done this two time to intall my intake and to replace a broken headlight, I can say that it took me about 20 minutes the first time removing it for the headlight with no previous experience and no instructions to go off from. The second time removing the front bumper for the intake it took roughly half that long
Old Oct 26, 2007 | 10:46 PM
ne0lain's Avatar
where am I?
Thanks guys... the exhaust went on in under 20min. It was so easy. The car only has 10000 miles on it, and i have owned it for two days now. These cars are a blast to drive. But what I still don't like is my 1.8t beetle had more hp(266/312 to the front) is there anything else i can do without affecting my warranty?
Old Oct 27, 2007 | 12:06 AM
Jon316G's Avatar
Grasshopper
Short answer... no!
If you're worried about the warranty, only thing that would help is to reduce weight and take care of your engine (keep up with the maintenance). Maybe focus on suspension and tires so that you could maneuver better on the track.
Think about going FI once the warranty (or your patients) is gone.
Old Oct 27, 2007 | 12:26 AM
Dont worry, that beetle cant beat you.
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
TJSiegrist
Sep 10, 2015 09:29 AM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Rupanrx
Sep 4, 2015 06:44 AM
