turn signal bulbs to match headlights?
Old Oct 19, 2007 | 06:38 PM
solesko7's Avatar
i just put in a pair on 10000k ds2 low beams, now my turn signal lights totally dont match, (they look green compared to the headlights) Does anyone have a link or know what kind on 7440 bulbs i can get to match the 10000k headlights?
Old Oct 19, 2007 | 07:06 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Your turn signal lights have to be amber, so what are you talking about?
If you mean side markers and or running lights, I would suggest 5 LED refractor by VLED in bright white.......which will be a little blue.
After I re-read your post again(this one because you started a couple), you are talking about the turn signals because the are 7440's..................they have to light amber! I use Stealth bulbs in there and like the effect because you don't really see them until you turn on the turn signals.
Old Oct 19, 2007 | 07:16 PM
solesko7's Avatar
i never use amber in my turn signal always blue! need to find ones that will match or be close to the low beams color 10000k
Old Oct 19, 2007 | 07:22 PM
Mazurfer's Avatar
Well.......you could try these then.
http://frickinbrite.com/catalog/prod...roducts_id=132
I know the color they should come out which will be just a hint of blue.
You are really going to have to try different ones until you find a match or do some searching in here because there are some threads that talk about all these lights and what matches what. I'll post here if I find it, but it is a good thread and had a link to a very good website showing the different colors based on numbers chosen.
Good Luck!
JimmyBlack
273
Feb 10, 2020 10:23 PM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
yankeepicker
Sep 11, 2015 05:42 PM
