Replacing rear O2 sensor
Old Oct 16, 2007 | 09:57 AM
Rotor Kreuzer's Avatar
The 8th Deadly Sin
Searched but couldn't find anything on this. How difficult a DIY is this? A guide for this would be much appreciated, thanks.
Old Oct 16, 2007 | 08:00 PM
Unplug electrical connector...remove sensor...replace sensor...redo electrical connector......
How difficult it is depends on if you have a lift or not...will take longer on your back on the ground
Old Nov 10, 2007 | 09:24 PM
ARC.4.LYFE's Avatar
now the question is where does the oxygen sensor plug into??
because upon looking under my 8 the other day i noticed the oxygen sensor wire harness melted to the side of my cat..and with no lift its hard to see where it goes. this may sound retarded but......plz help!
Old Nov 10, 2007 | 09:42 PM
plugs into the cat.. once on a lift it is obvious.
Old Nov 10, 2007 | 09:47 PM
ARC.4.LYFE's Avatar
i mean the other end...the wire harness
Old Nov 10, 2007 | 10:36 PM
once you get under the car you will find it..
92trbolzr
May 18, 2025 09:04 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
tjohnmeyer
Sep 28, 2017 05:03 PM
drlubell
Sep 26, 2015 11:58 PM
Forevermore
Sep 20, 2015 01:04 PM
