Iridium Plugs
Old Oct 14, 2007 | 08:45 PM
Jr8's Avatar
Jr8
Iridium Plugs
Is there a diff. part number for leading and trailing
Old Oct 14, 2007 | 08:59 PM
Old Rotor's Avatar
Yes....I did a simple search and found this...
http://www.sparkplugs.com/results_ap...1&AAIA=1416844
Old Oct 14, 2007 | 09:12 PM
Jr8's Avatar
Jr8
thanks
sorry im new too the RX8 scene and not sure were to go for parts and items
Old Oct 15, 2007 | 01:18 PM
Nubo's Avatar
Lubricious
Yes, the two plugs are very different as you see on the site (run your cursor over each part). Don't mix them up when installing.
Sparkplugs.com seems to have the best price. Go for the NGK, which is original equipment. The Denso are not better, despite their higher price.
Old Oct 16, 2007 | 02:01 PM
Now that I can find them. I'm gonna try a set.
Old Oct 29, 2007 | 05:54 PM
SHOWOFF's Avatar
NOT SEARCHING
JESUS CHRIST I can't get over how much plugs cost for this car.
I'm not sure if I need coils, plugs, or a new intake manifold, but over 7,000 I lose power badly and I can hear a fluttering sound that happens at or over 7,000 RPM.
Old Oct 29, 2007 | 06:07 PM
that *fluttering* sounds comes from the last Aux port connecting together (opening) and Thermostat opening fully (water flowing really fast sound)
Plugs cost more for this car because :
- Its new design
- This plug is designed for this engine exculsivly
- Its not mass produced like other plugs (Main cause)
if RX8 sells like Civic, Im pretty sure the plugs would cost 5 bux a pop.
but if rx8 sells like Civic, I wouldnt even consider this car.
Coil cost about 25-30 each. Coils die because Mazda tried to cut cost this and that. but ended up shootin' themselfs in the foot.
Old Oct 29, 2007 | 10:50 PM
i would first change the coils.. you might peak into the cat also.
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
Tweaked Tay
Sep 25, 2015 07:54 AM
iphil
Sep 21, 2015 10:49 PM
Forevermore
Sep 20, 2015 01:04 PM
Vedivan1
Sep 18, 2015 12:39 PM
