Drove with loose oil fill cap
Old Oct 13, 2007 | 08:38 AM
User24's Avatar
I failed to completely twist down the yellow engine oil fill cap after a top-off, and drove a significant distance. What type of damage may that have caused to the engine?
Old Oct 13, 2007 | 08:49 AM
wcs's Avatar
wcs
no agenda
IMO none
zero
zip
nad-da
You would only have to worry if dirt or debris dropped down the oil fill tube. This would only likely happen if the cap was left off.
Old Oct 13, 2007 | 08:53 AM
mac11's Avatar
Rotary , eh?
i drove an entire track day without a dip stick. you'll be fine. why are you worried? seriously.
Old Oct 13, 2007 | 02:27 PM
tajabaho1's Avatar
Destroying Threads
did you get a cel? nothing really, if u did just reset the ecu and avoid unneccessary trip to the dealership
Old Oct 13, 2007 | 03:01 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Like everyone else has said...................."nothing", you just probably should check the level again just to be sure no oil was lost, but if you had.....you'd probably have seen white smoke by now, so just check the level to be sure.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
drebbrnator
Dec 27, 2018 07:02 PM
TeslaMSI
Dec 10, 2015 01:10 AM
wankelbolt
Sep 9, 2015 03:43 PM
wayloco
Sep 1, 2015 09:03 PM
