Having problems with VIS CF trunk, anyone else have?
Old Oct 11, 2007 | 10:16 AM
turok4n64's Avatar
I Am Turok!!
Just installed the VIS Carbon Fiber trunk yesterday and while it does latch and close, there seems to be some major air openings on the left and right side. I'll try to take pictures when I can, but was wondering if this is normal
Old Oct 11, 2007 | 11:47 AM
XRX8X's Avatar
more then a Mazda
don't worry just give it to me and forget about it!my car is t.grey and the match would be perfect!!oh and that extra air room would go away after i sqeeeezzzze the two 1/4 panels together a little bit.j/k hope you find a cure.
Old Oct 11, 2007 | 02:10 PM
cornrowdpantha's Avatar
Read to succeed please...
A local member (DaddyLo) noticed the same issue with his CF trunk (I think it was VIS). If I remember correctly, he said that he had spoken to the manufacturer about it, and they stated that this was intentionally done in order to allow rain water to get to the drainage passages... He said that he hosed down the trunk to see if this was correct, and he found that no water actually got into the trunk beneath these raised edges (I'm assuming that you're referring to the raised edges along the sides of the trunk?). Thus, he assumed the the factory guys weren't pulling a fast one...
Send DaddyLo a PM and he can explain it better than I can, as my memory seems to be a bit fuzzy...
Old Oct 11, 2007 | 03:42 PM
06carbon8's Avatar
i have the vis trunk too. i had the same issues, and the company rep i talked to on the phone told me the same thing. i guess since someone else has said the same thing, they weren't just bs'ing me. mine is raised up a bit on the sides too, and i was nervous since i have 600$ worth of stereo in my trunk hahahah. after 8 months mine hasn't leaked once, so you should be fine. i was just worried that somehow i got a trunk that was screwed up.
Old Oct 11, 2007 | 10:29 PM
turok4n64's Avatar
I Am Turok!!
thanks guys, i was quite worried about the upcoming rain!
Old Oct 13, 2007 | 07:04 PM
Kel Rx8's Avatar
if your not 1st your last
I also have this trunk and noticed that with out the rubber seal, around rim(black)
on the trunk it sits perfectly flush. I left it off for a few days but put it back on since the look of the trunk open and missing the strip looks like crap.working on another Idea cause the raised trunk pisses me off and everyone tell me that.
Old Oct 13, 2007 | 10:16 PM
nightracer8's Avatar
I have had the same problem! I like the trunk and it looks good on the car, but i am sick and tired of everyone pointing out how it doesn't fit perfectly flush so i took it off last week. I put the original back on.
Old Oct 13, 2007 | 10:19 PM
if its not closing shut try pushing down harder on it. i have to do that to mine..
Old Oct 13, 2007 | 11:04 PM
WoodsOfGreenRx8's Avatar
Hmmm.. I wanted the CF Trunk but this causes me to vaulter a bit. Deeb, do you have the same problem.. Anyone have the Seibon trunk?
Old Oct 15, 2007 | 02:00 AM
CoMBo8's Avatar
My 8 is Sexy!
not sure about seibon trunk, but re-amemiya cf trunk wont have this problem.
Old Oct 15, 2007 | 05:36 PM
You know for a fact?
Old Oct 15, 2007 | 05:39 PM
BigRed's Avatar
w8nkel
anyone have pics of how bad the gap is?
WranglerFan
Aug 21, 2022 01:29 PM
nowakm99
Oct 9, 2015 07:10 AM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
To The Wonder
NE For Sale/Wanted
Sep 12, 2015 12:35 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
