Rev limited Japanese Spec RX8
Old Oct 10, 2007 | 10:06 AM
tblair's Avatar
Hello everyone,
I just signed up this morning. I live in Jamaica and have owned a 2005 RX8 (Red, MT, leather, sun roof) for the past 2 years. I bought it directly from Japan, so it has the Japanese spec - i.e. rev limited to 5,500 rpm in 5th & 6th gears.
1) Does anyone know how I can remove this limiter?
2) I need a new oxygen sensor and have checked the Internet (the local Mazda dealer does not support the RX8) . I see ads for 1 wire, 2 wire, 3 wire, 4 wire sensors. Which one should I purchase?
Old Oct 11, 2007 | 12:24 AM
Ike's Avatar
Ike
Blue By You
So do you have a 4 port MT?
Old Oct 11, 2007 | 12:29 AM
Zero_Rotary's Avatar
Double 8
he did mention 6th gear so should be 6 port engine..
Old Oct 11, 2007 | 03:40 AM
rotor_man's Avatar
something is wrong, 6mt is definetly the 6port motor and should rev out to 9k
Old Oct 11, 2007 | 04:55 AM
c41250n's Avatar
i guess he meant the computer limited the rev on 5th and 6th gears!
but.......do they do that?
Old Oct 11, 2007 | 05:05 AM
DMRH's Avatar
All Jap spec cars have a 180km/h speed cut in them.
Knightsports does the 4BEAT ECU upgrade. That removes the speed cut on your car.
REgards
Old Oct 12, 2007 | 05:32 AM
rotor_man's Avatar
HKS also do a speed limit remover DMRH, i just had mine installed today, Have not seen if it works yet, my drive home i would luck to get over 80k lol. It used to cut out at 187kmh, from memory 4th would only be just going so i guess 7k rpm.
I am 99% sure that the speed limit restriction is the only one C4... Just a hunch as to what is wrong but could the computer be detecting something wrong and cutting the power at that revs. Because if it carried on it might break.
Old Oct 12, 2007 | 05:56 AM
Rotor Kreuzer's Avatar
The 8th Deadly Sin
Get the 4 wire one. Or better yet, get an OEM replacement at onlinemazdaparts.com. Hope that helps.
Old Oct 15, 2007 | 05:40 PM
tblair's Avatar
You are correct. This rev limit corresponds to 180 kph, and also applies to the Evos and WRXs that come here direct from Japan.
I'll check on the sites sugested for the fixes.
Thanks for the assistance
ladnarf1
Apr 29, 2021 11:53 PM
dbarber
Jul 25, 2015 01:34 PM
shambo
Jul 18, 2015 02:07 PM
